Pstart command running programs simultaneous
  • kristofv
  • February 29, 2024 at 9:14 AM
  • kristofv
    51
    Hello All,
    I'm trying to run two programs simultaneous.
    One with a turn table S1 and one with the robot R1.
    The goal is that the (welding) robot goes to it's cleaning station while the turn table gets in position to save time.
    I'm using the Pstart command.
    the turntable program is made in group S1
    the robot program is made in group R1
    However, if I make a test program were i put two Pstart commands for either job it does not work.
    Nor does it work when I use the Pstart command for one program inside the other program.
    Does this have something to do with the sub1, sub2, .... tasks?
    Could someone give an example of how to put it in the controller.
    (YRC1000)
    Thank you all in advance for the help!
    This is what i do, that doesn't mean it's the right way to do it. :smiling_face:
  • Motouser
    39
    288
    • February 29, 2024 at 11:04 AM
    The main program must be a NO GROUP PROGRAM.
    JOB1 in S1 OR R1(but no for a NO GROUP, coz is used by the main)
    JOB2 in a different group from JOB1(but no for a NO GROUP, coz is used by the main)
    The pwait are optional.
    /JOB
    //NAME MAIN
    //POS
    ///NPOS 0,0,0,0,0,0
    //INST
    ///DATE 2023/12/14 12:15
    ///ATTR SC,RW
    ///LVARS 0,0,0,0,0,0,0,0
    NOP
    PSTART JOB:JOB1 SUB1
    PSTART JOB:JOB2 SUB2
    PWAIT SUB1
    PWAIT SUB2
    END
  • kristofv
    51
    • February 29, 2024 at 11:19 AM
    Thanks for the quick reply!
    I can understand the part between NOP and END.
    Could you clarify the above or is this just as an example and not useable data?
  • 95devils
    235
    8
    1,951
    • February 29, 2024 at 11:41 AM
    Quote from kristofv
    The job is an example of what you would see when it is opened in a text editor. Name of the job, number of positions in the job, date and time of the last edit, etc. It is information that is viewed in other screens on the pendant.
  • kristofv
    51
    • February 29, 2024 at 11:54 AM
    Thank you guys!
    I will give it a go!
  • kristofv
    51
    • February 29, 2024 at 12:46 PM
    So I gave it a go and the controller doesn't give an error but the programs do not run.
    It just goes to END.
    I've uploaded a picture of the main job and will upload a picture of the 2 other programs right away.
    Images
      • 126.75 kB
      • 900 × 1,200
      • 4
  • kristofv
    51
    Here are the other 2
    Images
      • 144.47 kB
      • 900 × 1,200
      • 2
      • 131.26 kB
      • 900 × 1,200
      • 3
  • roboprof
    24
    473
    • February 29, 2024 at 3:29 PM
    Switch between SINGLE mode and MULTI mode. Either hold down SHIFT and press 4, or go to SETUP - TEACHING CONDITIONS and switch between SINGLE and ALL there (near the bottom of the screen)
    If you are in SINGLE mode, nothing will happen when you do INTERLOCK+TEST START. You have to be in MULTI mode instead.
  • kristofv
    51
    • February 29, 2024 at 4:12 PM
    I changed the single mode and it works perfect!
    Thanks roboprof , 95devils and Motouser for your help!
  • PSTART
  • simultaneous
Users Viewing This Thread
  • 1 Guest
