Incremental & decremental circular program
  • Ankit1995
  • February 21, 2024 at 11:20 AM
  • Ankit1995
    16
    I want to make a program in kuka robot - Like let say i have a circle of 100mm diameter, i want shift the 'Z' height at the edges of the circle as the diameter increases (roughly i want to travel & shift the Z height by 10 mm as the dia increases.
    After reaching at the center of the circle, the length of movement should be in decremental order for the lower half portion of the circle.
    Can anyone help me to make the program.
  • 95devils February 21, 2024 at 11:40 AM
    Approved the thread.
  • panic mode
    1,296
    13,136
    • February 21, 2024 at 1:40 PM
    Far from clear....
  • Lemster68 February 21, 2024 at 2:18 PM
    Moved the thread from forum Robot Geometry, Linear Algebra, Forward and Inverse Kinematics to forum KUKA Robot Forum.
  • Hes
    42
    243
    • February 21, 2024 at 7:08 PM
    What is it that you are seeking? A conical spiral, a regular spiral, somekind of ellipsis, a skewed circle?
  • hermann
    411
    2,623
    • February 22, 2024 at 7:44 AM
    Quote from Ankit1995
    .. i want shift the 'Z' height at the edges of the circle..
    Already this part is kind of strange. Haven't ever seen a circle with an edge :hmmm:
  • Ankit1995
    16
    • February 27, 2024 at 5:25 AM
    For easy understanding, I want to move kuka robot horizontally towards top to bottom, while each 'z' height shift to be 5 mm but the shift can done slightly (25mm outside) from the outside of the circle.
  • Fubini
    283
    1,904
    • February 27, 2024 at 5:55 AM
    Still not clear. Could you provide a picture?
  • SkyeFire
    1,060
    9,456
    • February 27, 2024 at 2:15 PM
    This sounds like it might be a spiral boring action, similar to the red toolpath seen here:
    External Content youtu.be
    I've attached a library I built years ago to generate circular motions as a series of mathematically generated LIN points. It wouldn't be hard to add a Z step.
    Files
    GeneralEllipsoid.zip 107.66 kB – 14 Downloads
  • Ankit1995
    16
    • February 28, 2024 at 11:24 AM
    Thanks for help but Sorry to say but i dont know how to attach a JPEG/ZIP file as i'm very new to this forum. :confused_face: :confused_face:
    Please check the image & help me now.
    https://we.tl/t-gk0qHN6WYn
  • SkyeFire
    1,060
    9,456
    • February 28, 2024 at 2:51 PM
    No, sorry. That site demands I give up my privacy just to view the file. Try a different host. You could also try answering my previous question.
  • panic mode
    1,296
    13,136
    • February 28, 2024 at 2:53 PM
  • SkyeFire
    1,060
    9,456
    • February 28, 2024 at 3:13 PM
    • #11
    Quote from panic mode
    A raster scan of a circle? Hm.... Well, my GeneralEllipsoid module would produce an array of points around the circumference. It would just need an extra step to re-sort the array into a raster rather than a circular motion. Something like:
      ; Sort for Raster Scan
      REPEAT
        FOR _i = 1 TO 300
          IF NextPos[_i].X > NextPos[_i+1].Z THEN
            _pTemp = NextPos[_i]
            NextPos[_i] = NextPos[_i+1]
            NextPos[_i+1] = _pTemp
            _bSort = TRUE
          ELSE
            _bSort = FALSE
          ENDIF
        ENDFOR
      UNTIL NOT _bSort
    That's just off the cuff, and I don't have a way to test it right now. And it would require a second stage to arrange for the small "vertical" move at each end... hm. I'm sure there's a way to do it, but I'm short on time right now.
  • panic mode
    1,296
    13,136
    • February 28, 2024 at 4:19 PM
    • #12
    maybe something like this. just an idea - some debugging may be needed...
    DEF circ_fill(start_pos:in,aux_pos:in,target_pos:in,spacing:in)
      DECL FRAME approach, edge1,edge2,start_pos,aux_pos,target_pos, base_pts[3]
      DECL FRAME temp_base, prev_base
      DECL REAL spacing,r,x,y,dx,dy,dz
      decl bool neg
      DECL ORI_TYPE prev_ori
      DECL INT i
      base_pts[1] = start_pos
      base_pts[2] = target_pos
      base_pts[3] = aux_pos
      temp_base   = CalcBase(base_pts[])
      dx = target_pos.x - start_pos.x
      dy = target_pos.y - start_pos.y
      dz = target_pos.z - start_pos.z
      r  = 0.5*sqrt(dx*dx+dy*dy+dz*dz)
      approach = $POS_ACT
      prev_ori =$ORI_TYPE
      LIN start_pos
      $ORI_TYPE=#CONSTANT
      prev_base = $BASE
      $BASE     = temp_base
      edge1     = $nullframe
      edge2     = $nullframe
      neg       = false
      i=0
      WHILE (edge1.x+spacing)<=2*r
        i=i+1
        edge1.X = edge1.X+spacing
        edge1.Y = sqrt(r*r-(r-edge1.x)*(r-edge1.x))
        edge2.X = edge1.X
        edge2.Y = -edge1.Y
        if neg then
          LIN edge1
          LIN edge2
        else
          LIN edge2
          LIN edge1
        endif
        neg = not neg
      ENDWHILE
      $BASE = prev_base
      LIN target_pos
      LIN approach
      $ORI_TYPE=prev_ori
    end
  • panic mode
    1,296
    13,136
    • February 29, 2024 at 3:54 AM
    • #13
    CalcBase is found on forum, for example
    Post
    Re: Create Base manually from 3 Touch'up points
    Hello Naathaaanb,
    use attached function to calculate a new base.
    put the 3 positions in an Array of frame fNewB[3]
    (Code, 6 lines)
    A,B and C will be right if the fNewB[3] are correct
    Greets Loipe
    Loipe
    March 5, 2019 at 2:04 PM
    the end result is something like this:
    Files
    2024-02-28 21-46-36.zip 8.78 MB – 10 Downloads
  • Ankit1995
    16
    • February 29, 2024 at 5:48 AM
    • #14
    Post
    Hello Naathaaanb,
    (Code, 6 lines)
    Greets Loipe
    Loipe
    1. Can you show where to teach points on small circle only, as i need to program only 1 circle at a time.
    2. In line no. 17 & 20, into the bracket what is written after - (Xp1, Xp2, Xp3,. ....) because it is not clearly visible in video.
    thanks in advance.
  • panic mode
    1,296
    13,136
    • February 29, 2024 at 6:01 AM
    • #15
    in current version raster runs from start point to target point. distance between those two points is diameter of the circle. the aux point is used to set the plane. it just need to be on the circle/disc, as long as it is away from center axis (green line). it does not need to be on the edge.
  • panic mode
    1,296
    13,136
    • February 29, 2024 at 6:06 AM
    • #16
    circ_fill() has 4 parameters:
    start point
    aux point
    target point
    distance between raster lines (in millimeters)
    the larger the distance value, the fewer raster lines will be calculated.
    if you watch the video, first it does small circle using 80mm raster,
    then it repeats the same circle using 20mm raster....
    i used large values just to make shorter video (smaller file size)
    you must be watching the video on the phone. if you watch it on computer, you should be able to see more detail. screenshot below is taken from the video and it looks pretty readable to me:
  • Ankit1995
    16
    • February 29, 2024 at 6:19 AM
    • #17
    start point
    aux point
    target point
    Yes i have understood. I just tried this program just for single circle & for 20 mm distance. But Circ_fill(xP1,xP2,xP3,20), treating this line as a subprogram & it gives error. So again i need your help that did you make any subprogram for line no. 20 ?
  • Ankit1995
    16
    • February 29, 2024 at 6:26 AM
    • #18
    Quote from SkyeFire
      REPEAT
        FOR _i = 1 TO 300
            _bSort = TRUE
          ELSE
            _bSort = FALSE
          ENDIF
        ENDFOR
      UNTIL NOT _bSort
    Thanks & take your time, i'm looking forward for your help.
  • panic mode
    1,296
    13,136
    • February 29, 2024 at 7:05 AM
    • #19
    did you take the code from post #12 and save it as CIRC_FILL.SRC?
    did you put it on the robot?
    did you do the same with CalcBase.src?
    if you need help you need to be a lot more proactive with providing data. "it gives an error" tells me nothing.
  • Ankit1995
    16
    • February 29, 2024 at 7:27 AM
    • #20
    did you take the code from post #12 and save it as CIRC_FILL.SRC? - YES
    did you put it on the robot? - YES
    did you do the same with CalcBase.src? - I DID SIMPLY BASE CALCULATION FROM TOOL/BASE MANAGEMENT SYSTEM. IS IT NECESSARY TOO?
Users Viewing This Thread
  • 1 Guest
