$OV_PRO change only for selected moves
  • DavidSlany
  • February 20, 2024 at 12:07 PM
  • DavidSlany
    Hello everyone,
    Please how to change the speed of the robot only for selected movements? It is possible to use the code in case of change:
    $OV_PRO = 75
    LIN
    LIN
    CIRC
    LIN
    PTP
    $OV_PRO = 100
    Will it work or is it better to use it via a trigger and call the speed change from another file?
    Thank you verry much.
    Have a nice day.
  • Go to Best Answer
  • HawkME February 20, 2024 at 12:09 PM
    Approved the thread.
  • hermann
    412
    2,624
    • February 20, 2024 at 12:46 PM
    You should go the official way.
    Set speed by bas(#vel_cp, 1.25)
    And bas(#vel_ptp, 75). Values are only examples.
    Override normally is set by user on panel.
  • panic mode
    1,296
    13,136
    • February 20, 2024 at 3:46 PM
    • Best Answer
    programmed velocity should be done like hermann suggested.
    leave the operator controls to operator. and $OV_PRO is one of those...
    i do not like when program controls this, specially when it is continuously writing to it like in a Submit, operator should always be able to reduce it... if doing this, at least make sure it is only a limit, do not prevent user from reducing value.
  • Ravo
    111
    • February 21, 2024 at 6:52 PM
    I’m using variable $vel.cp=(0-2m/s)
  • Hes
    42
    243
    • February 21, 2024 at 7:26 PM
    this is somewhat unrelated but still on topic. As the others suggested you should leave $OV_PRO alone as far as possible and only use it when you really have to, set speeds for each motions as they are meant to be set as hermann adviced.
    I compared the diffrences between system variables documentation for 8.5 and 8.7 some time ago and low and behold.. I found what appears to be a sparingly documented golden nugget: $VEL_APPL
    This fills a gap for the applications where one was forced to hammer $OV_PRO if one absolutely had to adjust speed at runtime. (Or use rsi)
    With $VEL_APPL one can adjust the speed at runtime for cp motions with a few logical restrictions. Speed is capped at programmed speed.
  • xSajkox
    10
    • February 22, 2024 at 7:54 AM
    Quote from DavidSlany
    Hello everyone,
    $OV_PRO = 75
    LIN
    LIN
    CIRC
    LIN
    PTP
    $OV_PRO = 100
    Have a nice day.
    You can use that. I only suggest that you make variables with which you can monitor the speed in the program in several places with one change.
    For example:
    $OV_PRO=Full_Speed
    PTP
    LIN
    PTP
    PTP
    $OV_PRO=Working_Speed
    PTP
    LIN
    PTP
    $OV_PRO=Full_Speed
    PTP
    PTP
  • DavidSlany
    • February 28, 2024 at 1:33 PM
    Thank you all so much for the comments. I am wiser. We used the variable $vel.cp . Thanks again.
  • $ov_pro
  • RYCHLOST
