Hello to all,
In the following link there is a small application to make backups of the MD through the network.
please fill free to comment/suggestions.
best regards
Nuno
Hello to all,
best regards
Nuno
Has anyone tested the software yet ? I have tested only in one small line ( 40 robot's) but I want to know if it works with much more robots ...
Thanks in advance,
Nuno
Thanks for this application . I try to test it soon.
You should change the default folder naming scheme to descending order, YYYYMMDD instead of ascending order DDMMYYYY, so that an alphabetical sort will always be a chronological sort as well.
New version released:
1.0.3.7
- Folder naming now like - YYYYMMDD
I want to test that program but..
Windows security detected "Win32/Wacapew.c!ml" virus.
anyway.
I think that backup process as like "All of above" in TP.
if possible backup to "ASCII(*.LS)" types, more usefull.
anyway.
Hi Saberlars,
Regarding the "virus" I have checked with several antivirus and I didn't find any threat ... could be something in your computer ?
About the backup, this is not a "All of above" backup this is a backup of the MD, in my opinion it's more useful than a AOA backup... and if you want only the .ls files you can select in the dropbox the file type that you want :
Bst regards,
Nuno
Chrome browser (Version 121.0.6167.140 / 64bit) notify virus warning when I start download (first time).
I just ignore that message and select KEEP download then, MS Security remove FanucBackup 1.0.3.7.zip file...
a few hours later, I'm try again download your zip file, its normally working.
I think, my PC System something wrong. I don't know what is problem ~_~;
I see extension types drop box!
good. here my suggestions.
[Save type selector]
I'd like extension filtering more easy use as like FANUC Teach pendant.
[UI add & Text modify]
Thank you!
