DCS enabling using IO
  • Samwebber44
  • February 12, 2024 at 10:55 AM
  • Samwebber44
    7
    Hi all,
    Is there any way to have a DCS user model only enable when a certain digital input is on?
  • PnsStarter
    94
    336
    • February 12, 2024 at 12:39 PM
    Hi Samwebber44,
    As far as I know this is not (directly) possible. (maybe I am wrong)
    You can use a different CPC with other UserModel attached.
    The CPC's can be disabled/enabled using various IO(types)
    Keep safety in mind!
    Backdate/TP-Tools: A small collection of tools that simplify the commissioning and programming of Fanuc robots. (github.com)
  • gpunkt
    136
    492
    • February 13, 2024 at 10:31 AM
    Look up DCS tool change (in the DCS-manual).
    That way you can specify to use [whatever tool is currently active]'s User Model in your CPCs.
    You do need to use safe signals to switch between the various user models/DCS Tool Frames. Also, this will make the DCS Tool Frames linked to your TCP/Tool Frames, so if changing the values of the TCP, you will need to apply changes to DCS.
Similar Threads
  • Setup of an additional Dead Man switch
    • lastwaun
    • August 1, 2022 at 7:49 PM
    • Fanuc Robot Forum
