  4. Stäubli & Bosch Robot Forum
Changed format of J206_SyCon_ENI.xml file to indent.
  • mil3k
  • February 1, 2024 at 11:15 AM
  • mil3k
    18
    75
    Hi all,
    I used to edit names of inputs and outputs to custom in this file. This time I follow the same way as usual, open the file and to my surprise instead of indent or semi indent file I had one line with 33289 characters.
    I compared the file with another one I created few months ago. The same hardware Staubli D24403000 and D24403100 v0.18. The old one was in readable, indent format. Meanwhile between last time and now I updated SRS2019 to 2019.11.1 version.
    Did Staubli change a format of j206_SyCon_ENI.xml file from indent to one line?
    Does anyone have similar experience and found out work around?
    Will Staubli ever figure it out that change signal names to something meaningful (as per Profinet setting up process) is common practice for some users?
    BR
    mil3k
  • klausi
    8
    37
    • February 2, 2024 at 10:39 AM
    • Best Answer
    Hi
    You may use notepad++ with XML tools.
    You may need to install XML Tools using your plugin manager in order to get this option in your menu.
    Try Plugins -> XML Tools -> Pretty Print
    Best regards
  • mil3k
    18
    75
    • February 2, 2024 at 10:44 AM
    Fantastic!!! It works.
  • klausi
    8
    37
    • February 2, 2024 at 12:29 PM
    Hi milk3k
    Please mark this thread as resolved .
    BR
  • Galet
    19
    141
    • February 4, 2024 at 7:36 AM
    Hello everybody,
    The difference is only in the Carriage return. The names are the same.
    Other solution to view and modify XML file : Excel !
    Have a nice day...
  • EtherCAT
  • SyCon
  • Channel name
