Roboguide Ripe connection and IIC configuration
  • wag_FFU
  • January 31, 2024 at 11:53 AM
  • wag_FFU
    86
    Hi, I ´m trying to configure a cell in roboguide with 2 robot using the IIC option (intelligent interface check) option
    I´ve configured the Host name and the cell RIPE to allows the 2 robot to communicate with each other, but when I try to calibrate the robot in interference menu, -> Calibration between robot I ´ve no robots to add to Manager/Member configuration.
    There is more to configure than cell-> Ripe setup and host comm ip address? Thanks
    Edited once, last by wag_FFU (January 31, 2024 at 12:02 PM).
  • Aermoe
    21
    • May 28, 2024 at 3:03 PM
    Hi there
    Has this been resolved? I'm also looking into setting up the interference option in Roboguide.
  • wag_FFU
    86
    • June 2, 2024 at 9:35 AM
    yes and no... The problem was than I´ve loaded the wrong options. but I ´ve tryied this option with 2 robot mounted on a 7th rail axis, and this option doesn´t work in this case.
  • Aermoe
    21
    • June 3, 2024 at 10:11 AM
    Wait it does not? I have the exact same setup. 2 robots on a single rail with inteference check. I was able to configure it eventually and it seemed to work in Roboguide?
  • wag_FFU
    86
    • June 4, 2024 at 9:54 AM
    Yes, it works with 2 Robot, with the first axis configured as linear axis, working on the same rail, but my case was 2 robot with 6 axis, moving on 2 different rails with the 7th axis. In this case this option doesn´t work.
