Hi there, I am programming a PLC and HMI for use with PalletPro and a FANUC robot. We want to give our operators a visual display of the palletizing status. I.e which laye,r how many units in layer on pallet. Can Anyone help with this? I see position and status registers, but I do not know how to query without a cycle stop to keep layers updated as it indexes. Any help is greatly appreciated!
Help with PLC querie for palletizing registers
MONIQUEZE -
January 30, 2024 at 2:48 AM -
Nation
January 30, 2024 at 4:18 AM Approved the thread. -
First, you need to establish a connection with the PLC, have you done that?
Secondly, maybe using the "RUN" function would help you. Make a programm to monitoring R[i] with group mask [* * * * * * * *] and RUN it parallel to the main prog. -
Leviafun - Thank you!
Yes, I have figured out the comms and sending G1 data for load and pallet info and stop cycle, etc. But what you said makes sense. So... I make a program on the robot side to monitor the registers that I need and it will respond with the group out that I designate? Do I need to add that into the WCELLMON.TP as well? or I guess, how do I run it concurrently with Palletpro?
I usually setup a group output for each piece of data I want to monitor. I just set the outputs in PLONPAL.TP after calling open_tool and pulse an output so that the PLC knows when to update the HMI:
@ pdl
Thank You!
