Limit switch to limit servo power on
  • PATROLLING
  • January 23, 2024 at 8:18 PM
  • PATROLLING
    24
    I'm wanting to wire in a limit switch into a DX200. I want to use said input to limit the servo power on unless its true. I also want to signal an alarm or message showing that this limit switch isnt operation engaged. Any input on how you would do it?
  • ljuba
    33
    5
    281
    • January 23, 2024 at 10:02 PM
    depends what do you want to do. If it would cut the servo just in automatic or in manual or both. In case of cutting servo signal in both, you need a way to take it out of that sensor....
  • 95devils
    230
    8
    1,934
    • January 24, 2024 at 12:48 AM
    Easily done in the ladder program. Use the Universal Input to drive the Specific Input (4xxxx) for whichever category Servo Off you want. Always though, think about a “get out of jail free card.” How to recover upon a switch failure.
    Since this is going through the ladder it is NOT safety rated. If you want safety rated the GSIN inputs would be used and a machine safety logic circuit written.
    An alarm might be easy or may require some digging in the ladder. Depending on the ladder you might be able to tie into an Auxiliary Relay (7xxxx) that is already mapped in the ladder or you get to write your own mapping. It possibly gets deep depending on what is currently in the ladder, but definitely doable.
  • PATROLLING
    24
    • January 24, 2024 at 12:14 PM
    I would only want to limit ext servo on. I want to be able to still turn servos on in teach. Basically I'm just putting a ladder stand on the fencing of the robot and I don't want the ladder left inside the work area of the manipulator or positioner. Requiring the ladder be removed from the cell didn't work. I'm trying this approach. So I need to use SIN#030 EXT SERVO ON?
  • 95devils
    230
    8
    1,934
    • January 24, 2024 at 2:46 PM
    40045 is external servo on. Are you starting the robot from a plc, hmi, or push button? This requires the controller to be in Remote Mode to work. They could still start the system in Teach or Play Mode from the pendant unless you have PP SERVO ON PROHIBITED. You could also PROHIBIT PP START.
    Me, personally, I would probably go the servo off route. Servos are off in Play unless the limit switch is in the correct position.
  • Robodoc
    56
    7
    1,058
    • January 27, 2024 at 2:36 PM
    hook it into your e-stop circuit.
    Only one question, if said circuit goes open how do you turn the servo on to move the robot back to allow servo to come on?
    Robodoc
  • PATROLLING
    24
    • February 7, 2024 at 11:59 AM
    I tied it into one side of the safety gate. All good. In teach the logic doesn't care if that door is open or not. So it doesn't throw the M-SAF alarm. Not worrying about the alarm for that specific switch.
Similar Threads
  • Newly acquired Kawasaki UX150 with C-Controller
    • DoesItExist
    • January 24, 2023 at 10:59 PM
    • Kawasaki Robot Forum
  • Supressing alarms
    • Hummermicke
    • August 14, 2023 at 10:15 AM
    • KUKA Robot Forum
  • Panasonic GII- E032 E4000 Overrun
    • Arrari
    • July 4, 2022 at 2:30 PM
    • Panasonic Robots
  • KUKA 1FK7081-5AZ91-1ZZ9-Z Encoder Pinouts
    • RustyRSA
    • October 18, 2022 at 4:46 PM
    • KUKA Robot Forum
  • Connecting Kuka Arm to Arduino using Media Flange
    • Pt13
    • March 31, 2022 at 7:13 PM
    • KUKA LBR IIWA
  • Kuka robot project and difficulties
    • Oatesy
    • December 17, 2020 at 5:59 AM
    • KUKA Robot Forum
