Kuka Palletizing Robot A5 Axis
  • jturn101
  • January 20, 2024 at 1:15 PM
  • jturn101
    8
    Hi all,
    I'm working on a Kuka palletizing robot (KR300PA_2 S C4 FLR) and the gripper is not running parallel to the object that it is picking (first time working on a palletizing robot). I can modify the angle by disabling $pal_mode and moving A5 but didn't know if there was a way to record this value or is it just done by remastering A5?
    As soon at $pal_mode is enabled A5 needs to be driven 180. Can i modify the 180 value somewhere in the system?
  • Werner Hampel January 20, 2024 at 1:32 PM
    Approved the thread.
  • Fubini
    278
    1,888
    • January 20, 2024 at 2:05 PM
    You can not change the flange orientation in pal_mode. This has been discussed in the past. Just use foroum search with keyword pal_mode.
    Pal_mode mode on a 5 axis palletizer is the same as on a 4 axis palletizing robot where the mechanical construction with a parallelogram enforces flange to be parallel to the robots base. This enforced condition is on axis level and not in Cartesian space. A5 is calculted from a2 and a3 to achieve the parrallelity. If you need a different oriention mount the tool with the required angle.
    Fubini
  • panic mode
    1,280
    13,083
    • January 20, 2024 at 2:52 PM
    with 5-axis robot is really a 4-axis robot since A3 and A5 are internally coupled and working as one axis. this has advantages for maintenance, used space etc. if the flange is not parallel with the floor, check mastering. beyond that, there is nothing you can do - if you need to change flange orientation, you need a 6-axis robot. that is if you want setting to stick (stay fixed).
    the only other option is to programmatically enable/disable pal mode at certain stages of the program. for example this could allow you to pick something that is not level (pal mode off) and place it when it is level (pal mode on) but the system is not meant for this and the computational support necessary for this is not there. for example this means that related positions would need to be axis type (AXIS or E6AXIS) and not Cartesian (POS or E6POS). same goes for jogging in case of touching up points or recovery. in fact using Cartesian mode to jog will likely lead to collisions as robot may move unpredictably. trust me, this is not a can of worms you want to open.
  • jturn101
    8
    • January 21, 2024 at 10:50 AM
    Thankyou for your replies. We ended up remastering A5 but still had the same issue. Ended up offsetting it slightly to bring it back parallel. I'm guessing it was still not correct as we didn't remaster A2 & A3. Will do a check mastering to see how far they are out.
Similar Threads
  • Real Time external control of Kuka using RSI
    • geraldft
    • May 8, 2020 at 7:57 AM
    • KUKA Robot Forum
  • Kuka palletizing mode message - what is it, and how to recover?
    • KaitechKilen
    • December 19, 2023 at 11:35 PM
    • KUKA Robot Forum
  • Help buy: KUKA TITAN 1000 vs ABB8700
    • Karaline
    • December 23, 2020 at 1:37 AM
    • General Discussion of Industrial Robots Only
  • KUKA KRC2 KR180PA Crashed into itself, what logs are available
    • MrSysInt
    • October 22, 2020 at 7:30 AM
    • KUKA Robot Forum
  • Measuring positions while moving robot
    • Brende
    • August 29, 2020 at 4:25 PM
    • KUKA Robot Forum
  • KRC2 palletiziing robot doing different movements in step by step mode than in continuous mode
    • robotecnik
    • May 7, 2020 at 6:57 AM
    • KUKA Robot Forum
