Roboguide User Frames not updating in Tree
  • gonzodicuo
  • January 14, 2024 at 12:07 PM
  • gonzodicuo
    Hi to everyone.
    Im using Roboguide and have added up to 30 User Frames during controlled Start instead of the 9 by default.
    The problems is that the tree does not update them so every time i use one that is not in the 0-9 range the robot goes back to 0 Frame.
    Do you know how to update this?
    Edited once, last by gonzodicuo (January 14, 2024 at 12:43 PM).
  • Fubini January 14, 2024 at 12:30 PM
    Approved the thread.
  • HawkME
    568
    3,268
    • January 14, 2024 at 1:51 PM
    I have seen that before and think it is a bug in RoboGuide. I don't know a way to fix it, but you could store user frames in PRs and then have a small program to set a UF = PR. Then you can have many frame definitions saved that you can load as needed by calling that program.
  • Nation
    Typical Robot Error
    537
    1,917
    • January 14, 2024 at 5:15 PM
    Try reserializing the robot and adding in an option you won't use (enhanced mirror image comes to mind).
    That might make roboguide "redo" the robot tree.
  • gonzodicuo
    • January 15, 2024 at 9:52 AM
    Thank you, after reserialize it worked.
