Help! Interfacing of Siemens S7 1200 with FANUC R-J3.
  • Jay5
  • January 8, 2024 at 11:57 AM
  • Jay5
    Hi All
    We have already installed system with R-J3 controller and Fanuc AIF01A module and Mitsubishi PLC installed. Can anybody Please tell me how this whole system works? Can we not connect Siemens Plc directly to Robot to control it? what is purpose of Fanuc AIF01A module? what sort of communication channel will be used PN/PB or Ethernet?
    Thanks in Advance
  • Werner Hampel January 8, 2024 at 12:08 PM
    Approved the thread.
  • panic mode January 8, 2024 at 4:04 PM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum.
    gpunkt
    121
    469
    • January 9, 2024 at 10:34 AM
    • Best Answer
    The AIF01A is an Interface module belonging to the FANUC IO Model-A series of I/O modules.
    The principle is that you need a rack for the I/O-modules on which you can put your digital/analog input and output modules. At the start of the rack, there needs to be an Interface Module (like the one you mentioned) that is connected to the robot controller's mainboard through the JD1A-connector.
    This way, the robot controller can communicate with the I/O-rack and read/write the I/Os.
    To answer your question we need to know if the robot controller is currently communicating with the Mitsu PLC through hardwired I/Os or through some kind of I/O communication bus (such as Profibus, Profinet etc.).
    If it's just the hardwired I/Os then it's easy as pie to switch the PLC from Mitsubishi to Siemens.
    The AIF01A is merely acting as an interface between the robot controller and the I/O-rack.
  • Jay5
    • January 9, 2024 at 4:54 PM
    Hi GPUNKT
    It is hard wired . Thank you for response it helped alot.
Users Viewing This Thread
  • 2 Guests
