nominal user frame setup
  • leidai5
  • January 7, 2024 at 2:22 AM
  • leidai5
    44
    Good day,
    I'm trying to use the 3-point method to setup the nominal tracking frame. When I try to teach the origin point, I get a message 'User Frames not allowed during record.'. Not sure what that means and how I get past it. If anyone has any advice on this, it would be greatly appreciated.
    Thanks.
  • gpunkt
    138
    492
    • January 8, 2024 at 10:59 AM
    Maybe switch to UF[0] (World) as the active UF when performing the setup?
  • leidai5
    44
    • January 8, 2024 at 5:56 PM
    Yup, that did the trick. Thank you very much.
    Maybe I missed it but I don't remember seeing anything about that in the manual. Also, I couldn't SETIND to 0 in the frame menu as it was asking for 1-9. I had to do it through the sys var $MNUFRAMENUM.
  • gpunkt
    138
    492
    • January 9, 2024 at 8:36 AM
    Quote from leidai5
    Hold SHIFT and press COORD, a small yellow box will appear in the top right corner of the screen. Use the arrow keys to go to User Frame and then press 0 (or whatever UF you want to set as active).
    Much easier and faster than having to go Menu-Setup-Frames-Other-User-Setind-number-enter...
    From this menu you can also set the active Tool Frame, and this can be done from wherever in the system you are.
  • leidai5
    44
    • January 9, 2024 at 5:52 PM
    Ahh yes, forgot I could do that. Thank you!
