SOP forward to DO??
  • NovaFlatline
  • January 4, 2024 at 10:58 AM
  • NovaFlatline
    31
    Hello, Keep it up everyone.
    I've been assigned an issue with a robot that has been giving me some difficulty. Random fault of (spot-063) scr short.
    When fault reset is pressed the fault clears, and press start program runs. On the UOP. Is there any way that I may tie the SOP fault signal into a DO signal for a strobe or a PLC fault counter? So that once this fault comes across my strobe signals operators?
    Much thanks.
  • AlanL
    22
    77
    • January 4, 2024 at 2:02 PM
    I don't know off hand if there is a direct mapping for a DO to an SOP, but you can use background logic. If you don't have an unused DO you can map one to rack 0, slot 0. Then background logic you can do DO[x]=SO[x]
  • gpunkt
    120
    457
    • January 4, 2024 at 2:04 PM
    You can map the UO[6] (FAULT) to a DO of your choosing.
  • NovaFlatline
    31
    • January 4, 2024 at 3:26 PM
    alan, thank you for replying. I am trying to link the fault signal to a strobe. I have looked into using interlock routing, to no avail. Still a bit confused.
    gpunkt, I know I can map the UOP to inputs, but can I map SOP faults to DO? Then how would I go about doing that. Have not found that pendant to face moment, but I am close.
  • Doctor_C
    33
    198
    • January 4, 2024 at 4:54 PM
    With a BG_LOGIC program, do what AlanL said. Then under setup, BG_LOGIC, put your program name in and F2 RUN
    Just has to be mixed logic with the parenthesis.
  • NovaFlatline
    31
    • January 5, 2024 at 1:22 AM
    @doctorc, I will look for that when I go in tonight. I'm not sure if my controller is compatible with that it is a 30i
  • HawkME
    568
    10
    3,268
    • January 7, 2024 at 3:41 PM
    UO[6] is a digital output. That is the solution, just use it directly.
Similar Threads
  • Kuka and directly connected sensors. Some hack ;)
    • Henry Sheppard
    • June 15, 2020 at 8:13 AM
    • KUKA Robot Forum
