  4. ABB Robot Forum
Help with error: Syntax error(136): Unexpected 'module' identifier comment ....
  • Maack10
  • January 3, 2024 at 3:18 PM
  • Maack10
    Hi guys! I have an error when applying some new code. The output window says: Robot_1100_500335_2/RAPID/T_ROB1/162(1,32756): Syntax error(136): Unexpected 'module' identifier comment .... 03/01/2024 15:11:20 General but when i double klick on this line it only says Symbol not found. Do you guys have any ideas? I can't see anything wrong when scrolling to my code.
  • Go to Best Answer
  • SkyeFire January 3, 2024 at 3:47 PM
    Approved the thread.
    DS186
    201
    1,076
    • January 3, 2024 at 4:12 PM
    Please post the complete code.
    DS186
    201
    1,076
    • January 3, 2024 at 10:14 PM
    Could you at least show the line of code where the error occurs?
  • Skooter
    172
    2,073
    • January 4, 2024 at 12:24 AM
    Quote from DS186
    In addition to DS186's request - please state which version RobotWare and which text editor is being used to make changes.
  • hermann
    412
    2,628
    • January 4, 2024 at 4:13 AM
    Quote from DS186
    And show the line right above the error code.
    Otherwise you will be on your own.
    Or delete the faulty lineand try again. If the error is gone think about your code on that line.
    My crystal ball has gone lost while sending it for polishing :winking_face:
  • Lemster68
    301
    2,490
    Blog Articles
    7
    • January 4, 2024 at 2:36 PM
    • Best Answer
    To get to the offending line, the box at the lower right needs to read "Hide declarations". And you should be viewing that module in any of its routines. Then, debug and "Check program" should be selected.
  • syntax error
