Verification of hardware clearances
  • Dawid Firlej
  • January 2, 2024 at 3:08 PM
  • Dawid Firlej
    33
    Do you have any proven methods for verifying the wear of individual axes in a 6-axis robot? I have a robot that moves a detail under a laser head fixed in place. Despite the fact that the endpoint of the path is the same as the starting point (only rotated 360 degrees around the Z-axis), it can be seen that it does not hit the same position.
    I would like to understand the cause of this phenomenon and estimate to what extent it is due to the worn manipulator and to what extent it is due to play in the gripper.
    Attached is a photo where a rotation of 359 degrees was performed as part of the tests.
    Images
      • 111.52 kB
      • 903 × 1,200
      • 15
  • doomedblue
    37
    • January 4, 2024 at 7:57 PM
    how old is your robot? the cut line itself looks like it is within the accuracy tolerance of a robot arm (but obviously idk for sure) did this problem just start?
  • fredmike
    • January 5, 2024 at 8:07 AM
    Sharing the image of the test with a 359-degree rotation adds clarity to your inquiry enabling others to better visualize and possibly offer more targeted solutions or insights. Your transparency in providing visual evidence is highly appreciated.
  • Dawid Firlej
    33
    • January 10, 2024 at 9:32 AM
    Quote from doomedblue
    The robot is from November 2015, and the exact model is YR-MH00050-J00. After complete cutting, the deviation between the beginning and the end is approximately 0.4mm. In the robot's specification, the only tolerance parameter I found was repeatability at a level of +/- 0.07mm, and indeed, each time the final error is about 0.4mm with a tolerance of +/- 0.07mm. The positional error always occurs in the same direction - when looking at the picture, the cutting end is always lower than the beginning, regardless of whether the movement is clockwise or counterclockwise.
    Until now, the laser has been roughly cutting the material, and the detail was finished on a CNC machine, so no one paid attention to the cutting quality after the laser itself. Recently, an idea emerged to cut the finished parts with the laser alone, and only then did we notice that there is a deviation that disqualifies the product. As an interesting fact: On another, similar machine with an ABB robot, it was possible to achieve the desired effect. There, smaller details are cut, and the robot is newer. Therefore, we are considering replacing the manipulator with a newer one, but first, we would like to determine unequivocally where the cause of the Yaskawa inaccuracy lies.
  • doomedblue
    37
    • January 10, 2024 at 2:51 PM
    have you tried to simply adjust your point? if the cut is off .4mm every time and its the same way every time why would you think the manipulator is wrong or inaccurate.
  • 95devils
    234
    8
    1,947
    • January 10, 2024 at 5:35 PM
    Quote from Dawid Firlej
    I found was repeatability at a level of +/- 0.07mm, and indeed, each time the final error is about 0.4mm with a tolerance of +/- 0.07mm. The positional error always occurs in the same direction.
    Off of this, your robot is repeatable. There is a difference between repeatability and accuracy. You can program around repeatability not so much with accuracy.
  • Dawid Firlej
    33
    • January 12, 2024 at 8:01 AM
    Since after a 360-degree rotation around the Z-axis, the TCP should be exactly in the same position, but it appears to be shifted by 0.4mm. The programmed rotation looks as follows:
    IMOV P010 TF
    IMOV P020 TF
    IMOV P020 TF
    IMOV P020 TF
    Where:
    P010 (0,0,2,0,0,0)
    P020 (0,0,0,0,0,120)
  • WattUp
    7
    96
    • January 12, 2024 at 3:56 PM
    Are you sure the robot is 100% perpendicular to the laser at the start? It would only have to be off by a miniscule fraction of a degree for that spiral cut to be uneven as shown there.
