single bit ECC error occured
  • robot-cnc
  • December 10, 2023 at 2:41 PM
  • robot-cnc
    10
    414
    Hi !
    Does anyone experienced this error when controller PC KRC2 , KSS 5.6.6, boot or when turn from hibernation? If press F1 resume, computer start and normal open. Nothing wrong after opening, normally run.
    I replaced RAM memory, but still get this message. What else could be?
    Thank you !
    Images
      • 221.12 kB
      • 1,920 × 865
      • 10
  • panic mode
    1,262
    13,027
    • December 10, 2023 at 3:46 PM
    Motherboard. Chipset includes memory controller...
  • robot-cnc
    10
    414
    • December 10, 2023 at 6:51 PM
    You mean RAID controller?
    I read that should replace RAID card.
  • hermann
    403
    2,593
    • December 10, 2023 at 7:02 PM
    Afaik there is no RAID controller in KRC2. Doesn't make sense, there is only one harddisc in the controller, connected directly to motherboard.
    ECC error normally comes from main memory (RAM), Didn't know that they had ECC memory, Thought that they have normal RAM, without ECC. May be the BIOS settings are wrong,
  • panic mode
    1,262
    13,027
    • December 10, 2023 at 8:28 PM
    Yup ... ECC check is related to RAM, not storage memory.
    ECC memory - Wikipedia
    en.wikipedia.org
    So things that could lead to failed ECC check are faulty RAM, memory controller, CPU, motherboard, or as hermann already pointed out, simply wrong timing.
    It costs nothing to try loading defaults, or intentionally select slower memory access.
    External interference would be very unlikely since both motherboard and PSU are shielded, in a sense acting as Faraday's cage
  • robot-cnc
    10
    414
    • December 11, 2023 at 12:45 PM
    I think I solved the error cause. I replaced motherboard 3V BIOS battery. In Bios data setting wasn't kept saved on 2023 , it was returning at 2000 default data. After battery replacing seems to keep saved actual data and is ok, no single bit ECC error appears while starting.
    Old battery had only 1.5 V, ...discharged !
Users Viewing This Thread
  • 1 Guest
