Fanuc robot fixture servo OVC alarm
  • JohnG
  • December 1, 2023 at 5:01 AM
  • JohnG
    10
    Currently running a laser robot with a turn table and two servos mounted onto the fixture that will vertically rotate the fixture with the servo doing the work. So there is two sides of the table A and B and both sides will fault out when running in auto and even when I jog the fixtures from the robot group 2 and group 3 they will fault out also. I have changed out the servo amp and still getting the fault. No cables look damaged which I might check again. But I’m not to sure what else to do to get the OVC alarm to go away except for cycling power.
    Any way to disable this alarm in the variable settings.
    Thank you
  • R47
    110
    • December 1, 2023 at 9:35 AM
    Hi JohnG,
    are you talking about ab brand new Cell or was the line running in the past? If not maybe wrong setting for the tables.
