PAYLOAD DEFINITION
  • Evstahi
  • November 30, 2023 at 4:52 PM
  • Evstahi
    29
    One q. about payload definition we have a (ROBOT LINK) M-20iD/35 and by the software program we have gripper properties as follows:
    coord system is oriented the same as on robot so the values are the same.
    Mass: 25.54kg
    Center mass
    Z=17,4
    X=-10,8
    Y=-0,08 in fanuc value cm
    inertia:
    X=10,76
    y=12,52
    z=5,91 in fanuc values kgfcms2
    If we look the wrist load diagram we are under the 35kg, mark and when we set all in tool definition we get that the tool is in overload.
    But its a bit odd if we set all parameters to value "0", and try to set payload to idk 30kg we also get overload.
    Can somebody explain why is that?
    Images
      • 195.77 kB
      • 1,825 × 1,200
      • 20
  • Go to Best Answer
  • Nation
    Typical Robot Error
    522
    1,900
    • November 30, 2023 at 7:37 PM
    You look good to me. Are you using Fanuc's Excel based payload calculator?
  • hermann
    403
    2,593
    • December 1, 2023 at 5:22 AM
    Have a look into the units of the center mass. :winking_face:
  • Evstahi
    29
    • December 1, 2023 at 9:50 AM
    Quote from Nation
    we have changed to SI units in $SI_UNIT_ENB, so we have the same as in your excel.
    But yes when we entered the values the warning is still the same :thinking_face:
  • Evstahi
    29
    • December 1, 2023 at 9:58 AM
    You think that values are to high?,....because we were quite precise when we were putting all the mass definition in 3D modeling
  • Nation
    Typical Robot Error
    522
    1,900
    • December 1, 2023 at 6:21 PM
    • Best Answer
    I ran a test on that robot is roboguide, and I was getting the same "overspec" alarm as you are.
    I then discovered that Fanuc sets the J3 armload as 12kg by default. That value directly subtracts from the allowed payload on J6. Set that to 0, and it will work.
  • Evstahi
    29
    • January 19, 2024 at 2:07 PM
    Quote from Nation
    Yes that was the solution...Thanks for the out of the box thinking
  • DS186
    198
    1,048
    • January 19, 2024 at 2:44 PM
    Quote from Nation
    With FANUC the relation/combination of armload and payload depends on the robot model. It is not always payload = allowed payload - armload. There are different "rules" depending on the robot model.
Similar Threads
  • Inline position definition
    • emielke12
    • November 9, 2023 at 10:27 PM
    • Yaskawa Motoman Robot Forum
  • How to determine the maximum payload for a robot
    • payloader
    • April 6, 2022 at 4:32 PM
    • General Discussion of Industrial Robots Only
  • Ggg
    • kwakisaki
    • November 2, 2021 at 9:33 AM
    • Kawasaki Robot Forum
  • Payload
  • Payload Configuration
