Ethernet IP setup for Belden 0980 ESL 310-121 - LioN-P, EtherNet/IP I/O Device, 16DIO with fanuc robot
  • Looking for help setting up ethernet IP on Fanuc R30iB to talk to Belden 0980 ESL 310-121 - LioN-P, EtherNet/IP I/O Device, 16DIO.
    I have the .eds file and the config looks to be correct but still says it is offline.
  • Lemster68
    Approved the thread.
  • .eds files can be tough to look at. If you don't have something like it, I would start by downloading ez-eds and verify your settings against that. It's just a lightweight .eds viewer that displays the fields from the file in a nice format.
  • So this is for the Lumberg 313-121
    IP address 192.168.1.3
    Vendor ID: 21
    Device Type: 7
    Product Code: 31302
    Input size (bytes): 3
    Output size (bytes): 1
    RPI: 32
    Assembly instance (input):102
    Assembly instance (output):100
    Configuration instance :105
    Advanced settings
    I/O Data Type: 8-Bit
    Time out : 4
    Transport Type: Unicast
    O=>T Format : Run/Idle header
    T=> Format : Modeless
  • $ EZ-EDS Version 3.11.1.20151008 Generated Electronic Data Sheet
    [File]
    DescText = "EDS-V3.11.1-LumbergAutomation-0980ESL313-121-20160615.eds";
    CreateDate = 08-31-2015;
    CreateTime = 12:00:00;
    ModDate = 06-15-2016;
    ModTime = 10:00:00;
    Revision = 1.1;
    [Device]
    VendCode = 21;
    VendName = "Lumberg, a BELDEN Brand";
    ProdType = 7;
    ProdTypeStr = "General Purpose Discrete I/O";
    ProdCode = 31302;
    MajRev = 1;
    MinRev = 2;
    ProdName = "0980 ESL 313-121 8DI8DO M12P SP";
    Catalog = "934839-003";
    Icon = "EDS-0980ESL3xx-121.ico";
    [Device Classification]
    Class1 = EtherNetIP;
  • [Assembly]
    Assem100 =
    "Output",
    1,
    0x0000,
    8,Param2;
    Assem101 =
    "Input + Diagnostic",
    6,
    0x0000,
    16,Param3,
    8,Param33,
    8,Param4,
    8,Param6,
    8,Param7;
    Assem102 =
    "Input",
    3,
    0x0000,
    16,Param3,
    8,Param33;
    Assem105 =
    "Configuration",
    34,
    0x0000,
    16,Param17,
    16,Param18,
    16,Param19,
    16,Param20,
    16,Param21,
    16,Param22,
    16,Param23,
    16,Param24,
    16,Param25,
    16,Param26,
    16,Param27,
    16,Param28,
    16,Param29,
    16,Param30,
    16,Param31,
    16,Param32,
    8,Param34,
    8,Param35;
