Hi, i would need some help with my setup:
- KR C4 KSS 8.6.10
- KR 8 R2100-2 arc HW
- KP2-SV2600-HW
Option packages :
- SeamTech Tracking 3.1
- SeamTech Finding 3.1
- Ethernet KRL 3.1
- ArcTechBasic 3.5
- ArcTecAdvance 3.5
- ArcSense 3.5
- ArcTechMultilayer 3.5
- RobotSensorInterface 4.1
I am trying to weld a spiral tube attached to positioner, E2 endless rotation. Using scansonic laser to detect the welding position. Base is kinematically connected for the sensor to work using circ command for arc instructions. The problem is that all works fine untill positioner reaches approx 360 degrees then it will reverse resulting a collision. Any suggestions how to weld the whole part without stopping?
I tryed to move with nullframe on base on lin direction and it works but seamtracking does not read position as it moves another direction. Also arc velocity is not correct.
