We have a Kawasaki RS007N robot and I suspect something is wrong with the cartesian coordinates displayed on the TP.
The symptoms are:
- When the robot's joints are all 0s, X value is close to 0, however, Y value seems to have an offset of ~128 mm.
- When the robot is in the same position as described above, or other positions, its Z value is significantly greater than the robot's reach as described by the specification sheet of the robot (should be 730 mm, but values of up to ~1100 mm are seen).
- The positions have also been compared against RoboDK and ROS models, and they do not match with what is seen on the real robot's TP. When the same joint positions are input for the models, the robot position itself looks correct (looks just like the real robot), however, cartesian positions do not match between the models and the real robot.
What we've tried:
- Making sure Base Coordinates are set to 0s
- Making sure Tool Coordinate Data are all 0s (all of the tools are)
The only other idea we have right now is to check Robot Installation Posture, as it seems like it could change the Base Coordinate system orientation. As i do not have physical access to the robot, I am waiting for updates on the status of these settings. However, i do not believe that this could explain such a great difference in Z positions when considering robot's reach limits
Would anybody have any other ideas regarding what other robot settings could impact the cartesian coordinates, or is there something being overlooked here maybe?
Thank you for any help in advance
