  4. Kawasaki Robot Forum
array variable with program name
  • Robo_Dk
  • November 14, 2023 at 12:53 PM
  • Robo_Dk
    56
    Hello Everyone!!!!
    hope all members are doing well!!!
    I want to use local variables (.variable) with the program name, so anyone can help me or explain me how to use local variable with program.
    I am beginner for the AS language, so if anyone help me its helpful for me.
    test program for example,
    .PROGRAM Test(.variable)
    .a = offseto/10
    .b = offseta/10
    .c = offsett/10
    CASE .variable OF
    VALUE 0:
    POINT base = base0;
    VALUE 1:
    POINT base = base1;
    VALUE 2:
    POINT base = base2;
    END
    In above sample program how .variable value coming?, if anyone knows please explain how the value coming ???
  • Alexandru
    49
    407
    • November 14, 2023 at 1:05 PM
    .PROGRAM main
    instructions....
    CALL Test (r.variable)
    instructions
    If you change the variable value and call test program, the parameter has that value
  • Robo_Dk
    56
    • November 14, 2023 at 3:16 PM
    Quote from Alexandru
    .PROGRAM main
    instructions....
    instructions
    Thank you so much for your reply.
    I understood about Call instructions with array variable but I want to understand about this local .variable , how I get this value and how to use this value with CASE command?
  • kwakisaki
    694
    4,770
    • November 14, 2023 at 7:21 PM
    Check in AS manual, there are some very simple and basic examples that show the process.
    Do a search for Subroutine with parameters and look at example 1.
    Also do a search for local variable in AS manual, again it is explained.
    Local is local to program, so it needs to be defined locally in the program to be used....hence the term 'local'.
    It is differentiated by a 'dot' in front of the variable name and is local and not globally accessible.
    CALL monkey(1);
    .PROGRAM monkey(.variable):
    ; .variable will be defined by CALL parameter
    ; CASE will then pick CALL chimp to execute
    CASE .variable OF
    VALUE 0:
    CALL ape
    VALUE 1:
    CALL chimp
    ANY :
    HALT
    END
    .END
Similar Threads
  • Kawasaki problem with DELETE Multi Dimensional Array
    • elvicash
    • October 25, 2023 at 6:32 PM
    • Kawasaki Robot Forum
  • Staubli CS8: FTP Directory for VAL3 Programs
    • painful_staubli
    • June 21, 2023 at 7:33 PM
    • Stäubli & Bosch Robot Forum
  • Automating program upload to KRC4 via Ethernet
    • nicok
    • February 23, 2023 at 5:46 PM
    • KUKA Robot Forum
  • Traversing a Point List and/or Auto-Generating and Using Point Variable Names
    • EngineerTex
    • November 30, 2022 at 12:11 AM
    • KUKA Robot Forum
  • KRL Styleguide
    • Hes
    • October 29, 2022 at 1:10 PM
    • KUKA Robot Forum
  • Reverse-engineering AS programs
    • SkyeFire
    • May 31, 2022 at 9:35 PM
  • Algorithm for Recording Unspecified Number of Points KRC2
    • EngineerTex
    • April 7, 2021 at 12:36 AM
    • KUKA Robot Forum
  • Base transformation
    • benjamin21
    • August 11, 2020 at 1:23 PM
    • KUKA Robot Forum
  • Using interrupt to store values
    • chis
    • February 25, 2020 at 11:10 PM
    • KUKA Robot Forum
  • KRL to KAREL match cases
    • Latoff
    • February 13, 2020 at 9:52 PM
    • Fanuc Robot Forum
  • kawasaki robot control class
  • Kawasaki robot
  • kawasaki controller
  • Kawasaki Robot Controller
  • Kawasaki RS20
  • Kawasaki E Controller
Users Viewing This Thread
  • 1 Guest
