Import I/O comments on roboguide
  • Hello my beloved forum,
    I need to make some changes to a M-20iA/20M which is already working at a factory.
    My problem is related to the I/O comments. We are changing the gripper and I need to add some signals.
    Anyone knows why whenever I export my "IO comments" file on roboguide, it doesn't let me import it back? I tested without modifying anything, and it just says "import error".
    Thanks.
    "Hell...Yesterday it was workinG... I sweaR" :o)
  • Place your Ad here!
  • Yes, you can import/export IO from ROBOGUIDE software, you must do right-click on controller name and select "Export I/O Comments" to export and "Import I/O Comments" to import.
    I think you can modify with Notepad++ more easier, but be carefull at syntax.
    If you have a import error, maybe you must create a new project from real controller, and try again
    Otherwise export a I/O comments from a clean backup or other station (maybe virtual) and see with WinMerge the difference of syntax, maybe there is some header/instruction wrong.
