KUKA - Relative movement with a PLC variable
  • emusto
  • November 9, 2023 at 8:14 AM
  • emusto
    7
    Dear all,
    I need to do a relative movement with an offset declared by plc that change every time. ("Offset" Variable from a fixed point)
    I declared my INT signal in CONFIG.DAT and I m able to read his value.
    BTW I ve problems when using the LIN or LIN_REL movement and WoV says unexpeted string...
    Actually I ve tried whit these many attempts:
    LIN {Z offset_prelievo}
    LIN_REL {Z offset_prelievo}
    in both the cases WoV signal an error of unexpected string. But, if I write
    LIN {Z 100} is it ok!
    Can u give me some suggestions?
    Thanks for the support
  • MOM November 9, 2023 at 9:56 AM
    Approved the thread.
  • Fubini
    278
    1,889
    • November 9, 2023 at 11:07 AM
    That has been discussed many many times in this forum. Just use forum search. In KRL one can not use variables directly inside the target position. It needs to be a declared Variable so something along the lines of
    DECL FRAME myPos
    myPos.X = 0.0
    myPos.Y = 0.0
    myPos.Z = offset_prelievo
    myPos.A = 0.0
    myPos.B = 0.0
    myPos.C = 0.0
    LIN_REL  myPos
    Fubini
  • movement
  • relative
