  4. ABB Robot Forum
ABB IRB 1400
  • Kim Bak
  • October 30, 2023 at 11:17 AM
  • Kim Bak
    HI
    I have this error code when i start my robot
    Safdev.c 184
    safevtts. 527
    hope anyone can help :smiling_face:
    Kim Bak
  • HawkME October 30, 2023 at 11:45 AM
    Approved the thread.
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • October 30, 2023 at 1:00 PM
    What version of robot controller is it? Check connections of cabling inside and out of the controller.
  • Kim Bak
    • October 31, 2023 at 11:39 AM
    Hi Lemster68
    I will try unplug all cabel connections and clean them and then start it up again
    My robot is an ABB IRB 1400 M94A
  • Kim Bak
    • October 31, 2023 at 5:29 PM
    Hi
    I did not help cleaning all the cabel connections, it have not ben startet for seweral years, can it be the backup battery ?
  • byrol
    13
    5
    347
    • November 1, 2023 at 3:00 PM
    It looks like an error that came to the screen before the battery error. You may need to look at the wiring and especially the emergeny stop connection. Also, the error code may be 20527, not 527.
    Images
      • 186.07 kB
      • 1,127 × 565
      • 8
      • 104.48 kB
      • 1,207 × 403
      • 6
  • Skooter
    169
    2,025
    • November 1, 2023 at 11:06 PM
    Quote from byrol
    It looks like an error that came to the screen before the battery error. You may need to look at the wiring and especially the emergency stop connection. Also, the error code may be 20527, not 527.
    byrol - Those prints are for the S4C. I uploaded the IRB1400 M94A product manual to the Manuals sub found >here<.
  • Skooter
    169
    2,025
    • November 1, 2023 at 11:34 PM
    Kim Bak - Can you upload a picture of the TP screen with the errors and another of the CPU rack?
    DO NOT unplug the 3 boards (Main CPU, Robot CPU, Memory) on the right and DO NOT unplug the batteries while the power is off - that will corrupt the operating system.
  • Kim Bak
    • November 2, 2023 at 7:34 AM
    Hi
    Thanks for response. :smiling_face:
    I was so stupid and take the DSQC 335 out, for cleaning :frowning_face: and now it asks for the BOOT DISK
    I dont know why, but i cant upload any pictures
  • Skooter
    169
    2,025
    • November 3, 2023 at 12:02 AM
    If it passes the diagnostics, that's good. Just need the disks. Since you have a DSQC335 Robot Computer and likely DSQC325. Should also have the SBV/SDG EPROMs.
    Look for BaseWare OS 2.1 - it's very stable.
  • Kim Bak
    • November 3, 2023 at 7:26 AM
    Hi
    I have installed
    Baseware 2.0 V13 Boot Disk 1
    Baseware 2.0 V13 Boot Disk 2
    Baseware 2.0 V13 Boot Disk 3
    IRB 14.24.34.44. (1) 2.0
    IRB 14.24.34.44. (2) 2.0
    And now the robot works :smiling_face: :thumbs_up:
    Ihave these disks too, is it a good idea to install them too ?
    My robot is a welding robot.
    IRBP Disk 2.0
    Advanced functions 2.0
    Arcware 2.0
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • November 3, 2023 at 12:58 PM
    • #11
    IRBP is for a positioner. If the system no longer has that attached, then no. Advanced functions is good to have. ArcWare is for arc welding, so yes.
    I am assuming that the key disk license includes those options mentioned.
  • Skooter
    169
    2,025
    • November 4, 2023 at 12:31 AM
    • #12
    Quote from Lemster68
    Each Basic 2.0 disk and associated disks will have a partially encrypted disc.id file containing the same serial number. This works as an individual license key on each disk. Disks with different serial numbers would not load. You can view the serial numbers with a text editor like WordPad, NotePad++, etc. but DO NOT make any changes to the disc.id file or risk corrupting it. Key disks with disk packs started with S4C.
    As Lemster68 says, Advanced Functions can be useful and takes up very little memory.
    I would only load the ArcWare option if you are going to use it as a welding robot.
    Consider only loading the IRBP if you are using a positioner and your cabinet is already wired for it.
    Were you able to find a previous backup? That can save considerable time.
  • Kim Bak
    • November 10, 2023 at 10:53 AM
    • #13
    I have rebooted the robot with robware 2.0 and now it works again :smiling_face:
    Thanks for all the help
Similar Threads
  • Abb m98 bullseye software
    • PaulSola
    • July 18, 2023 at 5:19 PM
    • ABB Robot Forum
  • Manual for SIB V Type 1
    • jero
    • October 23, 2023 at 10:43 PM
    • ABB Robot Forum
  • abb irb1400 m98 firmware
    • Nifigace
    • August 1, 2023 at 2:05 AM
    • ABB Robot Forum
  • Abb Irb 1400 robot
    • iKSnIMAk
    • May 8, 2023 at 7:55 PM
    • ABB Robot Forum
    • iKSnIMAk
    • March 25, 2023 at 8:57 PM
    • ABB Robot Forum
  • ABB IRB 1400 ERROR 40168
    • Vlad2402
    • December 23, 2022 at 7:24 AM
    • ABB Robot Forum
  • Restauration IRB 1400 S4 M94 besoin disque avec Robotware 2.0
    • m.billot
    • June 24, 2022 at 2:38 PM
    • ABB Robot Forum
  • Technical Assistance
    • Md. Nasif Shuvo
    • December 10, 2020 at 2:22 AM
    • ABB Robot Forum
  • Abb irb 1400 m98/m97a gearbox manual
    • PaulSola
    • May 29, 2020 at 12:17 AM
    • ABB Robot Forum
  • Robot stand (Floor mount base/Robot pedestal) for IRB 2400 /w IRBP K-500 1400/2500
    • DanezDK
    • May 21, 2020 at 10:56 PM
    • ABB Robot Forum
Users Viewing This Thread
  • 1 Guest
