Roboguide - Profiler speed
  • GaliRob
  • October 29, 2023 at 12:52 PM
  • GaliRob
    I'm working on a welding simulation and the customer wants to know which speed the robot maintains during the trajectory.
    First I made a complex trajectory as the weld part needs, and then I analyzed it with the profiler.
    I observe that the robot is not capable of maintaining the speed, even if it is very low.
    Then i made a simple trayectory: 1 meter in a straight line to analize with the profiler. And the robot can't even keep the speed.
    For example: if I programm the lineal points with 50 mm/sec CNT 100 ACC 100, when i see the profiler... the robot reaches only 25 mm/sec
    I don't understand why the robot reduces the speed during the trajectory.
    ROBOGUIDE - Version 9 (Rev T)
    ORDERFIL.DAT:
    H552 HandlingTool
    H521 English Dictionary
    R806 ADV-CP Path Ctrl
    R805 ADV-CP Speed Ctrl
    J891 Adv. Constant Path
    R796 Ascii Program Loader
    R507 Ascii Upload
    R512 AutoSingularityAvoidM
    J618 CE Mark
    R534 Collision Guard
    J684 Collision Guard Pack
    R663 Constant Path
    J508 Customer Reg
    J523 Cycle Time Priority
    J567 DCS Pos./Speed check
    J568 DCS Safe I/O connect
    J755 Domain Name Serv.
    R834 Dual Chan. Profinet
    R651 FRL Params
    R553 HMI Device (SNPX)
    R558 Internet Conn/Custo
    R694 Jog in Auto Mode
    J766 Maint Reminder Plus
    J771 Maintenance Reminder
    R583 Motion Interface
    R809 Motion Package
    R641 PC Interface
    J744 PROFINET CP16XX FW.
    J931 PROFINET Safety
    J541 Password Protection
    R603 ROS Ethernet Packets
    R843 Remote iPendant
    R792 Singularity Avoidance
    R904 Spline Motion
    J694 TCP SPEED OUTPUT
    R726 iRCalib. Signature
    R765 iRDiagnostics
    FVRC Virtual Robot
    H721 R-2000iC/165F
    Any advice about this?
    Should I use or configure some motion option?
    Thanks in advance
  • Nation October 29, 2023 at 1:13 PM
    Approved the thread.
  • HawkME
    567
    10
    3,268
    • October 29, 2023 at 3:52 PM
    What is your override percent and program override set to?
    How long is your motion segment?
  • GaliRob
    • October 29, 2023 at 4:45 PM
    I set the Override in the program to 100%.
    In the Menu\Setup\Ovrd. Select is DISABLE.
    (Also, when i press "CycleSTart" and the program starts, in the quick bar at the bottom i see the Gen Override at 100%)
    The motion segment to analize is from P[2] to P[3]: 1000 mm.
    1:  !SimPRO Auto-Generated TPP ;
       2:   ;
       3:  UFRAME_NUM=1 ;
       4:  UTOOL_NUM=1 ;
       5:  OVERRIDE=100% ;
       6:J P[1] 100% CNT100    ;
       7:  !Segment1 ;
       8:L P[2] 50mm/sec CNT100 ACC100    ;
       9:L P[3] 50mm/sec CNT100 ACC100    ;
      10:L P[4] 50mm/sec CNT100 ACC100    ;
    /POS
    P[1]{
       GP1:
        UF : 1, UT : 1,        CONFIG : 'N U T, 0, 0, 0',
        X =  -200.000  mm,    Y =   300.000  mm,    Z =  -500.000  mm,
        W =     -.000 deg,    P =     -.000 deg,    R =      .000 deg
    P[2]{
       GP1:
        X =  -200.000  mm,    Y =     0.000  mm,    Z =  -500.000  mm,
        W =     0.000 deg,    P =     0.000 deg,    R =     0.000 deg
    P[3]{
       GP1:
        UF : 1, UT : 1,        CONFIG : 'N U T, 0, 1, -1',
        X =  -200.000  mm,    Y = -1000.000  mm,    Z =  -500.000  mm,
        W =      .000 deg,    P =     -.000 deg,    R =     -.000 deg
    P[4]{
       GP1:
        X =  -200.000  mm,    Y = -1300.000  mm,    Z =  -500.000  mm,
  • HawkME
    567
    10
    3,268
    • October 29, 2023 at 5:00 PM
    The robot should very easily reach that speed, something must be incorrect in your setup or how you are viewing the results.
    Check the system variable for program override.
    Also, try changing all move to Fine moves just for a comparison.
  • Nation
    Typical Robot Error
    522
    1,900
    • October 29, 2023 at 6:35 PM
    I ran a test on a similar cell, and got 50mm/s with your program, although I had to take some liberties with where the user frame was.
    Is this a restored robot, or a fresh one?
  • GaliRob
    • October 31, 2023 at 2:07 PM
    Sorry for the late answer.
    HawkME:
    With FINE i got the same result, the robot only reaches half of the programmed speed.
    Then I checked these 2 variables:
    $MCR\$GENOVERRIDE: 100
    $MCR_GRP[1]\$PRGOVERRIDE: 100.00
    Nation:
    I made the cell in RG (befores the robot arrived), then I serialized the robot with real one, but later we had to upload an image in the robot and serialized again.
    I created a new cell, and tried again the program and it works fine...robot reaches the programmed speed.
    Something I have observed is:
    In the crashed cell when I see the Profiler, there is an option: "Tool Posture" and in the new cell it doesnt appear. Maybe I marked some option and it causes this strange view of tcp speed.
Similar Threads
  • Motor torque analisys in Roboguide
    • Dm_23
    • October 3, 2020 at 10:22 AM
    • Fanuc Robot Forum
  • About Fanuc timer accuracy
    • Barry
    • August 7, 2020 at 7:20 AM
    • Fanuc Robot Forum
  • profiler
