Noob Question! Enabling pendant only teach on Fanuc 30ib Plus controller
  • Xcrysdale
  • October 26, 2023 at 11:03 PM
  • Xcrysdale
    Very new to robotics, learning from an expert with Fanuc robots but even he's not entirely sure the process/if it's possible + too busy :P... On our Kawasaki robots they've always been set to ignore the base station setting, meaning we can grab a pendant and flip into teach to make a change to the program. With the new Fanuc we just received, the 4 base stations are located on top of a press and not quite easy to flip back and forth for troubleshooting. If we could make it so the pendant determines Auto / T1/T2 and the base station listens for that it would save a lot of calories haha.
    I understand for production it's not standard to leave it enabled, however if we could change it for the tuning period that would be amazing. If it's referenced in a manual somewhere please let me know that so I can read through it and educate myself further, I couldn't seem to find it myself :frowning_face:
    Thank you for reading!
  • kwakisaki October 26, 2023 at 11:14 PM
    Approved the thread.
  • retobor
    17
    206
    • October 27, 2023 at 1:40 AM
    It is possible, but requires a jumper, software option, and modification of Safe I/O.
    Changing the mode without a mode select switch.
    Quote from Loipe
    “External Mode Select” option in the FANUC R30iB robot controller allows the robot cell integrator to use Safe I/O SSO(6) and SSO (7) to toggle the selector switch instead of using the actual switch itself.
    so there is an official Option for that. i had 2 robots with that. was really an improvment.
    old Mode selector gets replaced with a Jumper.
  • DS186
    200
    1,072
    • October 27, 2023 at 2:02 AM
    If you prefer a software solution, you could also buy the TP Mode Select option (J768). If you prefer a hardware solution, you could buy an external mode switch with an extension cable (up to 30 m).
