No TPP Memory
  • Mercadocs
  • October 26, 2023 at 10:29 PM
  • Mercadocs
    5
    Hello everybody.
    I have a Fanuc robot
    Model: P-250iB
    Controller: System R-30iB
    I had a lot of programs in my robot and I needed to load more. My robot was giving me a "MEMO-126 WARN No more available memory" alarm.
    I deleted a large number of unused programs and tried again, but I still get the same alarm.
    In the status/memory menu the tpp memory appears as follows:
    memory: 100kb
    Available: 10kb
    I don't know how to empty the memory to load more programs.
    Could you help me?
  • kwakisaki October 26, 2023 at 11:00 PM
    Approved the thread.
  • robot10000
    • October 26, 2023 at 11:16 PM
    The program you're trying to load likely exceeds the 10kb remaining
  • Mercadocs
    5
    • October 26, 2023 at 11:37 PM
    No, even when I want to generate a new program from the teach pendant I get the same "MEMO-126 WARN No more available memory" alarm.
    I have already deleted most of my programs
  • retobor
    17
    202
    • October 27, 2023 at 1:05 AM
    Well, it depends how big the unused programs that you deleted were.
    If I have a flash drive full of pictures and videos, and I delete all my pictures, is my flash drive empty? No, because videos take up a lot of space. Same with programs with hundreds of positions in them.
    Memory should free up as you delete programs, so I am assuming your programs are quite large. Unless there is another issue, I've never seen this before.
    I would take a backup, then try and delete more programs. On the select screen, I believe F3 and option 'size' will tell you how big each program is.
  • Mercadocs
    5
    • October 27, 2023 at 1:14 AM
    Before deleting the programs I performed an "all of above" backup and had 647 items (15.5MB) and now I have only 232 items (2.51 MB) in the "all of above" backup.
    I deleted programs of 4.5 KB or more and still did not increase my TPP memory.
    I really don't know why
    And I need to load these new programs, which weigh very similar to the deleted ones and are much less.
  • pdl
    266
    1,508
    • October 27, 2023 at 3:49 AM
    Try a controlled start and then try to load again after a cold start.
  • HawkME
    568
    10
    3,268
    • October 27, 2023 at 12:53 PM
    Post a screen shot of the actual memory values on the TP.
  • ROBOT_G
    23
    241
    • October 28, 2023 at 4:34 PM
    Any chance you're logging vision on the controller?
  • Mercadocs
    5
    • November 7, 2023 at 6:57 PM
    Im trying all your options and i dont have any good result, I don't know why
    I don't know how attach an image here to share with you the memory status
    in addition, some days I have 10,035 kb available space, some days i have 8,300 kb, and another days i have 1,050 kb, but i don't delete or load anything
  • massula
    200
    8
    1,421
    • November 7, 2023 at 7:40 PM
    Some years ago we had a problems with FANUC memory.
    In our specific scenario, we really have more (huge) programs than robot memory could carry, so in our case, the solution was order an option from FANUC called DRAM File Storage (R798), that enabled an additional memory section called Shadow Memory.
  • nantonson
    7
    • November 7, 2023 at 9:10 PM
    • #11
    Quote from massula
    the r30ib controllers should already have shadow memory, i would try cycling power after deleting the programs.
  • Mercadocs
    5
    • November 8, 2023 at 2:53 PM
    • #12
    yes it's a R-30ib, but the problem persist.
    I'm checking the programs files and I don't see any strange.
    I don't know what happen
  • hmmaint
    • January 17, 2024 at 3:33 AM
    • #13
    Hi
    Did you end up finding solution?
  • hmmaint
    • January 18, 2024 at 7:56 PM
    • #14
    Initial start fixed it!
    Image back up and reload
Similar Threads
  • Rj3ib paint robot, no core software
    • jgax
    • September 24, 2018 at 9:07 PM
    • Fanuc Robot Forum
  • Fanuc PAC codes
    • josephtoftjr
    • April 8, 2021 at 1:54 PM
    • Fanuc Robot Forum
  • Same trajectory, different tool - INTP-253 Tool frame mismatch
    • Darkbound
    • September 24, 2019 at 1:50 PM
    • Fanuc Robot Forum
  • TPP Memory
  • deleting programs
