  4. Kawasaki Robot Forum
KROSET - Stop gracefully program with while loop
  • dhindhimathai
  • October 24, 2023 at 4:13 PM
  • dhindhimathai
    15
    Hi all,
    Once again I'm here to ask for your help to solve a problem regarding Kawasaki robots and KROSET Lite simulator.
    I have a Main program in Kawasaki Robotics IDE that runs a communication thread and then enters a while loop to execute commands. You guys from this forum ( kwakisaki) have helped me write this and it works perfectly! :smiling_face: The code is roughly as follows:
    .PROGRAM Main () ; Main Program
      CALL Initialization
      WHILE TRUE DO
        ; Call the communication program
        PCEXECUTE 1:Communication
        ; Execute commands in a loop
        WHILE client_connected DO
          ; Execute commands
          PRINT "Executing..."
        END
        ; Do something else
        TWAIT 1.0
      END
    .END
    My question is more regarding KROSET and KIDE.
    I do the following at the beginning from KIDE (see the attached figure 1.png):
    1) I connect to the Kawasaki robot in KROSET simulation.
    2) I load the program onto the robot.
    3) I execute the program. Then, I can communicate and send commands to the robot in the simulation.
    However, how do I stop the simulation properly? How can I stop the program running on the robot simulation in KROSET?
    I tried to kill the background and foreground processes using the buttons highlighted in 2.png in the attachments... But, I'm sure there is a proper way to terminate the main program and the thread run from it.
    Thank you so much in advance for you help.
    Images
      • 109.85 kB
      • 1,918 × 82
      • 2
      • 118.86 kB
      • 1,920 × 121
      • 3
  • kwakisaki
    694
    4,770
    • October 24, 2023 at 8:15 PM
    If you are running it in the main program, due to your code, you have no 'exit' unless your comms exits your WHILES.
    So the only thing you could use is type ABORT in the terminal editor in KRoset.
    You could hit the emergency stop too or just toggle it back to teach mode.
    This will only stop the MAIN task though, your PC Task may keep running though.
    You could write a separate PC Task to manage the above and then set a couple of buttons on the IFP to stop and start it.
  • Stop
  • KROSET
