Question about accuracy cancellation between CALLS
  • kwakisaki
  • October 20, 2023 at 10:57 PM
  • kwakisaki
    694
    4,770
    Hi Guys
    I'm experiencing some accuracy/smoothing issues in motion.
    My example is I have a main JOB simply calling one JOB, then another JOB.
    If my last instruction in JOB is a motion instruction and I set it at PL8, it appears to be cancelled out by the call to the next JOB.
    Is this correct and is there something I can do to ensure the PL value is executed?
    Any pointers would be gratefully received.
  • kwakisaki October 20, 2023 at 10:58 PM
    Changed the title of the thread from “Question about accuracy type between CALL JOBS” to “Question about accuracy cancellation between CALLS”.
  • kwakisaki
    694
    4,770
    • October 22, 2023 at 8:31 PM
    I think the NOP instruction is the root cause of this.
    Is there anything that can be done about removing/nulling out this instruction?
  • Motouser
    39
    288
    • October 23, 2023 at 9:02 AM
    Hi kwakisaki,
    I imagine that your job is doing is that way:
    NOP
    MOVL Pxxx PL=8
    CALL JOB:ZZZ
    END
    As far as I know the PL is relative ONLY to the motion that you write in the job, even if you have a second movl in the main and you don't specify a PL it will result that the second MOVL doesn't have a PL.
    You have to specify a PL for each single motion instruction MOVL/MOVJ ...etc
  • kwakisaki
    694
    4,770
    • October 24, 2023 at 5:57 AM
    Thank you for your reply.
    In fact I just have a main Job consisting of:
    - CALL JOBX
    - CALL JOBY
    With 2 motion instructions in each with PL8 set per motion instruction.
    When executing the last motion instruction in JOBX with PL8, the motion instruction appears to be executed as though I have set PL0 instead.
    It appears that any PL value set is relative to that JOB only (this is what you are saying) and this is what I have confirmed too.
    I can only assume this is due to the NOP that Yaskawa insists on including at the top of any JOB.
    Would be nice to do something about this NOP, but I think this is permanent, is that correct?
  • Motouser
    39
    288
    • October 24, 2023 at 9:58 AM
    Quote from kwakisaki
    Yes both NOP and END are mandatory.
    Quote
    Not relative to the job, it's worse, it's relative to the single motion instruction:
    NOP
    MOVL Pxx0 PL=8
    MOVL Pxx1
    END
    In the example above, in the same JOB, the PL=8 is applied only to Pxx0. The second one has no PL specified. If you want a PL=8 then you will have:
    NOP
    MOVL Pxx0 PL=8
    MOVL Pxx1 PL=8
    END
    Quote
    Are you sure?
    PL=0 is the highest level, it will cause a temporarily stop of the robot like the highest ACCURACY in AS.
    You can set the PL "accuracy" from 1 to 8 with some S1C parameter in microns(S1CxG33...S1CxG40) but not for the PL=0.
    Check in the inform manual the MOVJ instruction.
  • kwakisaki
    694
    4,770
    • October 24, 2023 at 7:55 PM
    I've done lots of testing in this respect thanks to your information Motouser .
    Much appreciated.............. :top:
