KSS155054: workspace monitoring functions deactivated
  • Reflex
  • October 19, 2023 at 5:07 PM
  • Reflex
    133
    I'm using kuka agilus 2 with krc4 compact size and i'm facing some alarms like KSS155054: workspace monitoring functions deactivated ( mastering error)) and perform mastering on each axis. I read a thread who said that i need to check power supply kps-27 but i don't know where is located on cabinet krc4 compact size ?
    Any helps
  • panic mode
    1,297
    13,141
    • October 19, 2023 at 6:55 PM
    in KRC4 compact, that PSU is part of common PSU shown as "3"
    but... this powers everything so when 27VDC is not present, there is no power for the motherboard or CCU or for smartPad and you could not see those messages. in other words your PSU is most likely fine. if your robot is unmastered, you need to master it.
  • Reflex
    133
    • October 19, 2023 at 7:00 PM
    panic mode but the robot just yesterday working fine, i don't how it lost the calibration. is it normal ?
  • panic mode
    1,297
    13,141
    • October 19, 2023 at 7:07 PM
    when you drive a car and run over some nail, the car tire is likely to get flat. but it too was just fine yesterday. :winking_face:
    everything can go bad and usually it does if you give it enough of time - specially if things are not taken care of or when installed or messed with by unqualified personal.
    mastering loss can happen when SLA batteries are too low. then you just need to loose power and robot is unmastered.
    even if batteries are ok, things can go wrong. one of the common issues is collision.
    another one is loose data cable (X21-X31) for example when O-ring is missing, which makes connectors fit loosely and any movement or pull on the cable will cause a problem. This would indicate sloppy installation and result was simply ticking time bomb.
