ABB IRB 6640 Communication with CP1616 board
  • Hello,
    I have ABB IRB 6640 robot with Robotware 5.14. This robot has Profinet ms option and cp1616 profinet card on the main computer. I'm trying to make a communication between Siemens s7-1200 PLC and IRB 6640 via cp1616 profinet card but I couldn't do it. what I tried to do to make this communication in PLC and robot side are given below,
    PLC
    1. I upload GSDML 2.4 file of cp1616 card and 128b Input and Output module.
    2. I assign IP and and station name to the card and I can ping it. so that the card i set with the IP that its given.
    3. I also update the firmware of the card by TiaPortal
    Robot
    1. I create Profinet bus connection in the Robotstudio communication section. I use First Board
    2. After I create a bus connection , I set unit and unit type to make this communication happen
    I think the problem is I can not make cp1616 profinet configuration because it says that "No configured" in system info section. Also I can not create .xdb configuration file on Tiaportal.
    Has anybody same problem ?
    Thank you
  • yeah I use the GSDML file on the TIAPORTAL that comes in the robotware package.But I can not configure the CP1616. when I look into system info of the robot,It says no configuration for cp1616 on the robot side
  • [Environment]
    Robotware 6.** base.
    840-3 PROFINET Anybus Device Option
    DSQC-688 ProfiNet card installed at DSQC-1000
    [Robot]
    Configuration - I/O System
    1. PROFINET Internal Anybus Device
    - Name : PN_Internal_Anybus
    - Connected to Industrial Network : PROFINET_Anybus
    - Vendor Name : ABB Robotics
    - Product Name : PROFINET Internal Anybus Device
    - Identificiation Label : (blank)
    - Input Size (Bytes) : 64 (in 512 Bits)
    - Output Size (Bytes) : 64 (Out 512 Bits)
    2. Industrial Network
    - Name : PROFINET_Anybus
    - Identification Label : PROFINET Anybus Network
    - Address : Ask to PLC
    - Subnet Mask : Ask to PLC
    - Gateway : Ask to PLC
    - Simulated : No
    End of Robot EIO configuration.
    ※ Recommended Device Name Defaults.
    [PLC]
    1. Upload GSDML xml file.
    - 3HAC031670-001(DSQC_688) is GSDML-V2.0-PNET-FA-20100510.xml
    ABB, FANUC, Hyundai, Kawasaki
