I'm trying to load jobs from FTP but.. can't see "FTP Profile" in EX. MEMORY window.
While I go into MAINTENANCE MODE -> OPTION FUNCTION -> NETWORK FUNCTION SETTING I'm not able to switch ETHERNET option to USED.
Even if i change there the FTP option to STANDARD or EXPAND the ETHERNET option stays all time as NOT USED.
FTP - cant choose FTP Profile - YRC1000
bonczek -
October 10, 2023 at 2:07 PM -
Hi
You couldn't change this option by yourself, the Yaskawa must active it.
Contact Yaskawa for do it.
Hi
Thanks!
Is there any option to make sure that this option is not activated?
Maybe any Variable says it? Or any Window with active options? -
You send a picture that Ethernet is NOT USED, it show this option it's active.
When Ethernet isn't active, you couldn't use FTP function.
You may find it easier to install an additional program that supports FTP.
If you're trying to load files over FTP, you don't need to look for anything in the pendant except for the network setup and required parameters.
Take the IP address or set one up, and set up a server in FIlezilla and you should be able to send jobs over ethernet.
The image attached shows required parameter settings for FTP.
Better later than never - It requires "Yaskawa mode" as user level
