  4. ABB Robot Forum
how can i get the axes motor current?
  • owenlee
  • September 23, 2023 at 11:46 AM
  • owenlee
    5
    I currently have a project that requires monitor the current position of ABB with the PC, the torque and current of each axis motor. My method is to use ABB's PC SDK or Robot Web Services for reading, but I cannot find a method to read it. Does anyone know how to read it?
  • Fubini September 23, 2023 at 12:15 PM
    Approved the thread.
  • Mertkan Koca
    53
    • September 25, 2023 at 9:24 AM
    Usually multiple ways to see that also a software for checking signals which called by SignalViewer but it depents what model do you using, which controller ?
  • owenlee
    5
    • September 25, 2023 at 1:08 PM
    Do you mean the model of the robot? The model of the robot is IRB 1600. I have checked and found that a control module of 616-1 has been installed
    Quote from Mertkan Koca
  • Mertkan Koca
    53
    • September 25, 2023 at 2:53 PM
    Quote from owenlee
    Nice we got the version , and what about controller model ? IRB5 or S4C/S4C+ Do you have RobotStudio CD or RobInstall CD ? What is writing on controller ?
  • owenlee
    5
    • September 26, 2023 at 5:53 AM
    I checked the controller label and it marked 'type: IRC5 Single '. I have a version of RobotStudio that is 2019.5.5。
    And I tried using the PC SDK and was able to access the operating mode robot. GetController (0). OperatingMode normally. But still cannot found the electric current.
  • Mertkan Koca
    53
    • September 27, 2023 at 6:56 AM
    manual way i think you can check from axes drives inside the control panel . and the other way is
    Test Signal Viewer
    The Test Signal Viewer enables you to display motion test signals
    (e.g. external axes signals).
    this software should be inside the robotstudio installation files
    for more information like input and output currents please check controller pdf
    Files
    IRC 5_product specification_2019.pdf 8.09 MB – 127 Downloads
  • owenlee
    5
    • September 28, 2023 at 10:18 AM
    Test Signal Viewer
    Thanks a lot, I will read the pdf carefully. But in fact, I have also checked a lot of information, and basically can only check the torque of each axis normally. However, I can find no information about the current, and I hope I can find it in the PDF.
  • panbucik
    5
    • October 2, 2023 at 12:03 PM
    Hello all,
    I'm sticking to the post question and expanding a little - is it possible to get via ABB RWS (web services) current values of the below parameters?
    - joint velocity
    - joint acceleration
    - joint torque
    - joint temperature
    - joint current
    It seems the only available joint current value is joint position.
    Many thanks for any hints :grinning_squinting_face:
  • Mertkan Koca
    53
    • October 5, 2023 at 6:56 AM
    hello i am not much familiar with RWS but if you can reach and comminicate with robot for expample RAPID files you can see joint acceleration,velocity,torque and current.About temperature i think your robots model must have joint temperature sensors like , PT100 or else depents on your robot model specs
    Here is services about RWS , main services
  • owenlee
    5
    • October 9, 2023 at 8:43 AM
    Thank you for everyone's attention.
    I also tried RWS, but I couldn't find the variable for current yet.
    What was mentioned upstairs is correct; I just want to read these parameters except temperature:
    - joint velocity
    - joint torque
    - joint current
  • panbucik
    5
    • October 10, 2023 at 12:16 PM
    • #11
    Thank you Mertkan for your thoughts! It's true you can get to the RAPID files via RWS and read parameters of a specific line, e.g. MOVEJ jTarget, speed, but this would be a target speed (which might be even not achieved during the movement if the consecutive points lie close too each other) and the question is if there is a way to read the current value of the joint/tcp speed via web services and regardless what is written in RAPID code?
  • blueicaro
    31
    • October 17, 2023 at 9:36 AM
    • #12
    Quote from panbucik
    Hello, to read the tcp speed, you should use a system output attach a analog signal. Then you can subscribe to that signal using RWS
    /BlueIcaro
Similar Threads
  • How to communicate with a EtherCAT device in KRL
    • chiachingyen
    • June 12, 2021 at 11:38 AM
    • KUKA Robot Forum
  • Supressing alarms
    • Hummermicke
    • August 14, 2023 at 10:15 AM
    • KUKA Robot Forum
  • Kuka KR-200 Ackn regulator limit exceeded A6
    • Arwin
    • March 9, 2023 at 6:49 PM
    • KUKA Robot Forum
  • Waking up 2 - ZZX200S B Robots after long hibernation
    • colemajr
    • April 19, 2022 at 2:41 AM
    • Kawasaki Robot Forum
  • KR 210-2 2000 with KR C 2 battery question
    • soundwawe
    • March 24, 2022 at 10:04 PM
    • KUKA Robot Forum
  • Endless motion for KUKA external axes
    • capital9
    • February 3, 2022 at 7:42 AM
    • KUKA Robot Forum
  • Down the rabbit hole...Who wants to join in the fun?
    • Elderwild
    • November 30, 2021 at 8:25 PM
    • ABB Robot Forum
  • A1 motor overload
    • JamesTaco
    • January 7, 2022 at 3:04 AM
    • KUKA Robot Forum
  • Resurect a kr150L150 with KRC1 [OVERCURRENT ERROR AXIS 4]
    • tmuthesius
    • July 6, 2020 at 12:47 PM
    • KUKA Robot Forum
  • Oversized servo configuration on brand new KRC4? Is it possible?
    • RAS-Skordos GR
    • May 7, 2021 at 8:16 PM
    • KUKA Robot Forum
  • motor current
