USER FRAME blues
  • robotecnik
  • September 22, 2023 at 1:43 PM
  • robotecnik
    19
    568
    Hello all,
    I am working at a new customer who has set the typical 3 pins to create user frames not at 90º.
    I have a straight line in the XY axis (X1 to Y1), but the X2 position is not aligned with X1. In other words, the angle defined between X1-X2-Y1 is not 90º.
    Is the Fanuc robot capable to create a user frame this way?
    And will the Z axis work as it would in a perfectly 90º pins distribution?
    Sorry for this simple question, but I have never done this like that, and the robot is still not properly connected so I can't try it. And, as usual, customer is on a hurry.
    Thank you all in advance.
    http://www.robotecnik.com | Robots, CNC and PLC programming.
  • USURP_RUR
    8
    162
    • September 22, 2023 at 1:48 PM
    I do not see any problem yet. Do you know how to create a UserFrame using the "Four Point" method?
    The Z direction will automatically become 90 degrees normal to the X-Y plane and accordint to the Right Hand Rule.
    Edited once, last by USURP_RUR (September 22, 2023 at 1:54 PM).
  • robotecnik
    19
    568
    • September 22, 2023 at 3:55 PM
    Maybe I've not explained it correctly, at the end I've been able to speak with a Fanuc technician and he told me the plane orientation would be wrong, not a big deal, the customer will just mount the pins as they should.
    A pity I have not been able to test it directly... all would have been much faster.
    Thanks for your post!
  • TitusLepic
    112
    7
    442
    • September 22, 2023 at 5:04 PM
    I tested this on my RJ3iB (HandlingTool 6.4) a few years ago. The Origin-X axis defines the X axis direction. The XY plane is defined as containing the Origin-X axis and the Origin-Y axis (ie, the Y point controls rotation about the X axis). And the Z axis is orthogonal to the XY plane. So no, the angle doesn't have to be 90 degrees, but the Origin-X axis defines the X axis direction and therefore the orientation.
    SkyeFire
    1,052
    9,431
    • September 22, 2023 at 7:26 PM
    The 3-point method first defines the origin point. The second point defines the X+ axis, as a line from the Origin to the second point. The 3rd point defines a plane. The Z axis is perpendicular to that plane.
    So, the alignment of the 1st and 2nd points are critical. A line between the 3rd point and the Origin does not need to form a 90deg angle with the X axis, but whether it lies in the X+ or X- region (relative to the Origin) will determine if the Z+ axis points "up" or "down", and the "height" of the 3rd point relative to the Origin and X points will define the angle of the Z axis.
  • userframe
