Tool_Offset (FANUC) which is the equivalent to KUKA?
  • imurillo
  • September 20, 2023 at 1:19 PM
  • imurillo
    Hi everyone, i like know what is the instruction equivalent to Tool_Offset the Fanuc for KUKA
    Thanks colleagues!
  • Birch8101
    25
    • September 20, 2023 at 1:54 PM
    Im not sure for older versions of KSS but at least for KSS 8.7,
    Base Offset:
    LIN XP1:{X 0,Y 0,Z 0}
    Tool Offset:
    LIN {X 0,Y 0,Z 0}:XP1
    There are plenty of posts on the forum discussing this along with how to use a combination of different offsets in a single move.
  • Roland Keller
    5
    60
    • September 20, 2023 at 2:02 PM
    The variable of type Frame could be your friend.
    For example declaration:
    DECL FRAME fTool_Offset = {X 0,Y 0,Z -100,A 0,B 0,C 0}
    Motion:
    PTP pYourPosition : fTool_Offset
    LIN pYourPosition
    SkyeFire
    1,038
    9,371
    • September 20, 2023 at 7:16 PM
    There's no Offset command in KRL. Instead, you can command a motion to the result of a point calculation. So:
    TempPoint = P1 : {X 0,Y 0,Z 10,A 0,B 0,C 0}
    PTP TempPoint
    would have the same result as:
    PTP P1 : {X 0,Y 0,Z 10,A 0,B 0,C 0}
    The ':' is the Geometric Operator, which you can find many posts about in the Forum archives. But very briefly:
    P1 : {X 0,Y 0,Z 10,A 0,B 0,C 0} is a shift of 10mm along the Tool Z-axis.
    {X 0,Y 0,Z 10,A 0,B 0,C 0} : P1 is a shift along the Base Z axis.
  • imurillo
    • September 25, 2023 at 12:35 PM
    The problem is that, i don't want to overwrite the point, i want that this point to move knowing that he have other point that must that have in account.
    SkyeFire
    1,038
    9,371
    • September 25, 2023 at 4:02 PM
    Quote from imurillo
    You don't have to overwrite the point. In my examples, there was either a Temporary Point that was written to be an offset copy of P1, or the move command moved to an offset of P1 without rewriting P1.
  • TOOL
