Does anybody know wich variable holds comment for Utool and another fo Uframe? I set xyzwpr values, but i don't know how to change comments using code.
Setting comments for Utool and Uframe
- C_P
- Thread is Unresolved
Lemster68
Approved the thread. -
This does not seem to be a general robotics question. Please specify which robot make you are asking about.
I work on Fanuc Robot H705 CRX-10iA/L
panic mode
Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum. -
You can set the comment on same screen you taught the tool frame
On the Detail screen for the Frame, simply move the cursor to the Comment and hit Enter. Then you'll have the options to type out the name you want.
Here are the commands to set the frame comments programmatically, using a .cm file.
Display More! User Tool Comments KCL SET VAR[TPFDEF]SETUP_DATA[1,1,1].$COMMENT = 'UT1' KCL SET VAR[TPFDEF]SETUP_DATA[1,1,2].$COMMENT = 'UT2' KCL SET VAR[TPFDEF]SETUP_DATA[1,1,3].$COMMENT = 'UT3' KCL SET VAR[TPFDEF]SETUP_DATA[1,1,4].$COMMENT = 'UT4' KCL SET VAR[TPFDEF]SETUP_DATA[1,1,5].$COMMENT = 'UT5' KCL SET VAR[TPFDEF]SETUP_DATA[1,1,6].$COMMENT = 'UT6' KCL SET VAR[TPFDEF]SETUP_DATA[1,1,7].$COMMENT = 'UT7' KCL SET VAR[TPFDEF]SETUP_DATA[1,1,8].$COMMENT = 'UT8' KCL SET VAR[TPFDEF]SETUP_DATA[1,1,9].$COMMENT = 'UT9' ! User Frame Comments KCL SET VAR[TPFDEF]SETUP_DATA[1,3,1].$COMMENT = 'UF1' KCL SET VAR[TPFDEF]SETUP_DATA[1,3,2].$COMMENT = 'UF2' KCL SET VAR[TPFDEF]SETUP_DATA[1,3,3].$COMMENT = 'UF3' KCL SET VAR[TPFDEF]SETUP_DATA[1,3,4].$COMMENT = 'UF4' KCL SET VAR[TPFDEF]SETUP_DATA[1,3,5].$COMMENT = 'UF5' KCL SET VAR[TPFDEF]SETUP_DATA[1,3,6].$COMMENT = 'UF6' KCL SET VAR[TPFDEF]SETUP_DATA[1,3,7].$COMMENT = 'UF7' KCL SET VAR[TPFDEF]SETUP_DATA[1,3,8].$COMMENT = 'UF8' KCL SET VAR[TPFDEF]SETUP_DATA[1,3,9].$COMMENT = 'UF9'
