Hello all,
I must activate the TP to be able to keep working in a robot without TP.
It worked, something changed and now it is not working anymore, I can't access the irProgrammer, neither I can jog the robot.
If I select NAVIGATE IPENDANT (JCGTP) :: under the 3D display a yeld with "Turn the teach pendant enable switch to [on]" message appears.
If I select JOGGING IPENDANT (JITP) :: a white web page with "Auto mode is required" text appears.
If I select SOFT OPERATOR PANEL :: a white web page with a lot of text appears:
"SYST-244 Auto mode is required
Cause:
This operation requires Auto mode.
Remedy:
Change the mode switch to Auto.
SYST-245 Local mode is required
Cause:
This operation requires Local mode.
Remedy:
Change the mode to Local.
SYST-246 Teach mode is required
Cause:
This operation requires Teach mode.
Remedy:
Change the mode to Teach.
SYST-247 Master ON is required
Cause:
This operation requires a Master ON situation.
Remedy:
Ensure that the Master ON situation exists.
SYST-248 Alarm condition
Cause:
This operation requires no alarm situation.
Remedy:
Clear the alarm situation.
SYST-249 No system ready input
With all that information... given this is a robot without pendant, how could I activate AUTO and the TP?
Thank you all.
