Krc connection
  • hi, I am a new user of kuka robots. After a reboot with repeated reading of the files, it does not want to start, namely, it does not connect to krc. Previously there was a similar problem, but it was that another employee changed the IP addresses through Windows. I've already tried connecting an external monitor and smarthmi won't load on it either
  • kwakisaki
    Approved the thread.
  • details matter. connecting monitor to KRC will likely show blank screen... unless... you connect the monitor to KRC, make sure monitor is powered up and then power up krc.
  • Krc4, Windows is displayed on the monitor, smarthmi cannot start. smarthmi writes that there is no connection with krc
  • ошибки
    Посмотреть и скачать с Яндекс Диска
    disk.yandex.ru
    Photos of all errors are available via the link
    And I will immediately write a recovery flash drive, as well as the opportunity to get it
    please look at the message below, I will be grateful
  • please look at the messages below
  • Sounds like file corruption in KSS/VxWorks. This will probably require a re-install of the Windows/KSS core software.
    I may have found a problem, the absence of the vxworks.bin file, I tried to install it from another robot on kss 8.3, now it complains about the vxworks version. Does anyone have access to the robot on kss 8.2.22 I only need one file from there
    C:\KRC\ROBOTER\vxWorks.bin
