JZNC-YIU02-E Broken outputs
  • Mr.Czarli
  • September 10, 2023 at 12:22 PM
  • Mr.Czarli
    10
    Hello to everyone.
    A few days ago i turned on my robotic setup after almost a year. I remember that the last time everything working correctly. But now, relay connected on CN309 terminal cant switched on. I already tested another outputs and also another terminals (CN306) but nothing work. I can exclude wrong transistor on output because also outputs which is never used is also death. Voltage on terminal 24V is OK and two fuses in plastic case is also OK. No alarm on pendant. Everything working correctly in software level.
    Then i foud in documentation CUT FUSE LED (D2 FUSE) and is not lighting. I dont remember if during normal operation this LED diode was lighting or not. I'm not sure, if is any other fuse on DPS. What is mean not lighting LED - fuses are OK or blowed fuse?
    Anybody any advice or hints how to solve this hellish problem? Probably its gonna be some stupid thing.
    I remember, that the last time I try some new features and i working with parameters. Somebody know about a parameter which is possible to deactivate IO ports?
    Thanks for your help.
    Edited once, last by Mr.Czarli (September 10, 2023 at 12:33 PM).
  • HawkME September 10, 2023 at 1:00 PM
    Approved the thread.
  • kristofv
    51
    • September 11, 2023 at 2:37 PM
    We are having a simular issue for CN307.
    We also tested everything we could without any result.
    On thursday there will be a technician here from YASKAWA.
    If we can find a fix i will let you know.
    (please remind me in case I would forget).
    With kind regards
    This is what i do, that doesn't mean it's the right way to do it. :smiling_face:
  • Mr.Czarli
    10
    • September 11, 2023 at 8:08 PM
    I already had a communication with yaskawa guy. I mean just phone call where guy verify things on software level (universal outpus makes binary changes in external outputs). ...And card behavior is unnormal so probably broken card. But result without solution.
    Thank you so much.
  • Mr.Czarli
    10
    • September 15, 2023 at 7:52 AM
    Hello kristofv, do you have any possitive information from your Yaskawa guy? Did you fix it?
  • Mr.Czarli
    10
    • September 17, 2023 at 3:09 PM
    kristofv ...reminder :smiling_face:
  • kristofv
    51
    • September 18, 2023 at 11:13 AM
    Mr.Czarli
    Hello Mr. Czarli,
    My appologies for the delay.
    In our case the module apperently was not activated.
    We did the following to make it work:
    startup the dx100 in maintenance mode (press main menu while turning the main switch until you
    here a small beep)
    - go to system - security - management mode
    - go to system - setup - I/O module (select)
    - press enter x2 until it jumps to #st 19 and press enter again
    - a popup wil appear asking "modify?" --> select yes
    - a new screen appears (allocation mode) should be "auto"
    - press enter new screen #20010: 14 0 0 0 5 YIU02
    - press enter new screen #30010: 14 0 0 0 5 YIU02
    - keep pressing enter until the popup "modify?" appears again.
    - select yes: you will hear a small beep
    - the I/O module is now ready to use.
    Hope this helps...
    Edited once, last by kristofv (September 18, 2023 at 2:24 PM).
  • kristofv
    51
    • September 18, 2023 at 11:14 AM
    PS.
    In our case it was for the CN307 module...
  • Mr.Czarli
    10
    • September 18, 2023 at 4:08 PM
    Kudos to you kristofv ! :smiling_face:
    I repeated same steps like you describe in comment and its works. :smiling_face:
    Thousands time thank you. :smiling_face:
  • Mr.Czarli
    10
    • September 18, 2023 at 5:03 PM
    And just for sure.
    CUT FUSE LED also marked like D2 FUSE is not lighting if everything works corectly.
  • kristofv
    51
    • September 20, 2023 at 9:14 AM
    Mr.Czarli
    I'm glad to see it work :winking_face:
    If the 2 fuses in front are ok (by mesurement) then it should work.
    There is a third internal fuse but I wouldn't worry about that.
  • kristofv
    51
    • September 20, 2023 at 9:15 AM
    • #11
    PS. maybe mark the thread as solved so others know that there is a possible sollution. :smiling_face:
  • Mr.Czarli
    10
    • September 21, 2023 at 9:55 AM
    • #12
    Agree. Problem solved. Thank you. :smiling_face:
  • Yaskawa dx100
  • DOUT
  • broken
  • JZNC-YIU02-E
  • FUSE
