KUKA KRC2 ARCHIVE FAIL
  • AD3MIN
  • August 31, 2023 at 6:21 PM
  • AD3MIN
    57
    Hi all,
    I have KUKA KRC2 with Version V5.5.16
    I am unable to take backup of robot using USB or save it in any drives. When I click on File/Archive/All, It will show in screen as 'Save files' , unfortunately after some minutes it will show as 'archiving cancelled'.
    What can be the reason for this? can anyone kindly share your thoughts and recommendations.
    Please check the attached images for my 'Archive Manager'. I have a different robot with same archive configuration where I get archiving successfully completed.
    Thanks In advance
    Advmin
    Images
      • 284.11 kB
      • 1,600 × 1,201
      • 30
      • 227.3 kB
      • 1,600 × 1,201
      • 22
    SkyeFire
    1,052
    9,429
    • August 31, 2023 at 6:28 PM
    Never seen that message before. Did the Archiving work on this robot previously?
    Does the A drive still work?
    When you attach a USB drive, does it show up in the Explorer as U:\?
    panic mode
    1,280
    13,085
    • September 1, 2023 at 4:10 AM
    Check logs for details. Also try partial archive to narrow down the problem - try just programs or just message logs or just single file. It may be some locked file in which case one or more partial archives may work
  • AD3MIN
    57
    • September 1, 2023 at 5:03 PM
    Quote from SkyeFire
    Hai SkyeFire,
    Many Thanks for the reply,
    This robot was idle for a long time and it came from another site, I really do not know whether archiving was working before.
    Yes ,the A drive is in working condition
    Yes,I can see the Explorer as U:\ when I attach USB
    Regards
    Advmin.
  • AD3MIN
    57
    • September 1, 2023 at 5:19 PM
    Quote from panic mode
    Hai Panic mode,
    Many thanks for the reply,
    I have tried the partial archives, taking backup individually like Application/Machine Data/Configure/Log Data
    this steps worked ,I got archiving succeeded
    However, the application backup occasionally fails. After several tries, I will get a successful backup for application archive.
    Regards
    Advmin.
    SkyeFire
    1,052
    9,429
    • September 1, 2023 at 5:36 PM
    Well, with no obvious smoking gun, we're down to trial and error. Change one thing, try it out.
    1. Try multiple USB sticks
    2. Try multiple USB sockets on the KRC (including the ones directly on the motherboard)
    3. Try removing the A: path in KRCConfigurator
    4. Try removing the U: path
    5. create a backup directory on the D: drive, then point the default Archive path at it.
Similar Threads
  • Help with Kuka software
    • Tadej Valjavec
    • May 8, 2023 at 10:07 PM
    • KUKA Robot Forum
  • Kuka krc2 system ıstallation
    • paulfile
    • April 4, 2023 at 11:19 AM
    • KUKA Robot Forum
  • Kuka tool no.3: Kuka Archiving Automation
    • asimo
    • May 1, 2009 at 7:53 PM
    • Manuals, Software and Tools for KUKA Robots
  • Remove existing I/O, clean KSS, etc
    • kbekkala
    • July 27, 2022 at 12:18 AM
    • KUKA Robot Forum
  • Correct shut down on KR C1 and HDD clone
    • RobotRobert
    • September 13, 2021 at 12:04 PM
    • KUKA Robot Forum
  • archiving kuka Krc2 on floppy disks, KSS 5.5 archive failed
    • pe.mace
    • July 2, 2020 at 11:22 AM
    • KUKA Robot Forum
  • LOAD DETERMINATION AND KUKA.LOAD IN KUKA ROBOT
    • Counterspeller
    • May 14, 2020 at 1:52 PM
    • KUKA Robot Forum
