Sometimes my robot does weird extra spins to get to the desired rotation point, All moves are linear moves using Mrot and Wjnts. I'm trying to attached a video i took but i dont know how.
Pick and place vision robot spins weird sometimes
- Waynebot
- Thread is Unresolved
kwakisaki
Approved the thread. -
SkyeFire
Moved the thread from forum Manuals, Software and Tools for Fanuc Robots (you should look here first before posting) to forum Fanuc Robot Forum. -
You need to make your first move to above in Joint. This will keep the robot in it's taught configuration.
Using linears the robot wants to take the shortest path, then MROTS and such try to eliminate some of the strange motions
Can your object be found in 360 degrees? Might need to restrict this.
The joint move made my entire pick go out of position. Seems like if I removed the mrots and only put the wjnt on the first linear move it seems to have taken care of the issue. We ran well today from the feedback I was receiving.
the part is oriented all over a mass flow conveyor. It is a rectangular part and I can tell which way it’s facing and picking it a certain direction. A DEF bottle spout if your familiar
