Hello.
I have a problem connecting the robot to the local network.
I have a service connector to which I connect my laptop with the RobotStudio program. The robot has the address 192.168.125.1, the PC - 192.168.125.100. At the same time, everything works, I can switch between points and view information online. When I try to connect the robot to the local network (10.10.0.xxx) through the configured Mikrotik router, I can see it, but I cannot connect, it says that option 616-1 is not installed.
What could be the problem?
The service does not write anything back and does not respond, there will probably be movement only after the contract and payment...
