DX200 : move until signal is ON
  • Eurus
  • August 28, 2023 at 12:22 PM
  • Eurus
    5
    Hi everybody!
    I need some help for my first application on Yaskawa robot (and robot in general)
    So, my application involves an approximate reading of a distance between a fixed position and an object of variable diameter (so the distance varies).
    Based on this data the robot will approach the object up to about 10 cm; from there he will have to slow down and move quite slowly until he leans against the object. The distance to reach will be given by a very precise distance sensor located on the robot tool.
    At that point, the robot will be put into manual mode to perform more precise tests on the other sensors on the tool.
    Then, once the test is finished, the external automatic will be put back on and the robot will have to return to the home position.
    I really can't understand how can I program the robot in order to get the "move until the distance between your tool and the object is 0".
    I was reading the Instruction manual and I found the UNTIL instruction but the reading of the input seems to be quite slow ( MOVL V= 50.0 UNTIL IN#(1)=ON)
    Plus, I think I understood that I have to declare my MOVL... but I have no data to parametrize it (I don't know how big is the object , so I don't know the distance beforehand).
    Furthermore, how can I stop the motion and exit from the job that manages this positioning?
    ADDITIONAL INFO:
    the robot will communicate with a Siemens PLC S7-1200;
    there are no problem about cycle time: the robot will perform some kind of lab tests, so no need to speed up;
    Probably, the slow movment will be in Z- in tool coordinates
    I hope I explained the situation well eonugh...
    Thank you for any advice! :smiling_face:
    Eurus
  • kwakisaki August 28, 2023 at 12:42 PM
    Approved the thread.
  • MR21
    24
    • August 29, 2023 at 10:03 AM
    Which type of sensor are you using on robot tool?
  • Eurus
    5
    • August 29, 2023 at 11:18 AM
    Hello!
    We are going to use a Keyence LR-TB2000C
  • MR21
    24
    • August 29, 2023 at 12:38 PM
    Hello Eurus,
    Using the laser you know the distance between the fixed position and the object.
    This value is how much you should move to reach your object with the laser.
    In this way you don't use MOVL UNTIL..but only MOVL.
    Other way you can use a system job that reads the distance continuosly.
    You use a DO to know when the distance is 0, and in the LADDER you can map the output with the input.
    SYSTEM JOB
    IF (LASER_VALUE = 0) THEN
    DOUT OT #(33) ON
    ENDIF
    JOB
    MOVL P000 UNTIL IN#(33) = ON
    LADDER
    STR# 30070
    OUT# 20070
    ATTENTION:
    If you have defined your tool as the center of the spot of the laser, when the laser value is = 0 the laser (tool) is in contact with your object
  • Eurus
    5
    • August 29, 2023 at 4:56 PM
    Hello and thanks for your reply!
    The second option is exactly what our client requested from us
    I'm concerned about the communication speed, though. The sensor signal is read by the PLC, which evaluates if the distance is equal to 0 and signals it to the robot: isn't it a slow procedure to communicate the stop of the movement?
  • MR21
    24
    • August 29, 2023 at 5:52 PM
    To be faster I think you can use the SEARCH function with DIRECT INPUT.
    You can find something in the forum, for example here
    Thread
    Informations about SRCH RIN
    Hello guys,
    I need some help to understand better the line with SRCH command.
    What happens when this line is executed is that the robot search for the signal in Z and Y axis. And I can't figure out where have been set that robot know in which axes its going to search the signal.
    GETS PX001 $PX011
    CNVRT PX001 PX001 BF
    MOVL P001 BP001 V=15.0 SRCH RIN#(1)=ON T=0.20 DIS=25.0
    GETS B000 $B002
    JUMP *OK1 IF B000<>0
    :help: :help: :help:??? ??? ??? ??? ??? ??? ??? ??? ??? ???
    ljuba
    January 21, 2017 at 11:36 PM
    I have never used it and I don't know if the search input board is standard with your robot
    Files
    Sensor function instructions.pdf 2.65 MB – 39 Downloads
  • Eurus
    5
    • August 31, 2023 at 8:57 AM
    Hello!
    Unfortunately we don't have the search input board, that would be perfect!
    From what I understand, the search function is used to search for a point with certain coordinates and the movement stops when the point is found or when a direct RIN input is on/off (based on how it has been set), correct?
  • MR21
    24
    • August 31, 2023 at 9:50 AM
    Quote from Eurus
    Hello!
    Right!
  • Eurus
    5
    • November 25, 2023 at 12:11 PM
    Hi guys,
    the suggested solution seems to work!
    Thank you all :smiling_face:
