  4. ABB Robot Forum
Error code 100000: Internal error
  • ellim
  • August 21, 2023 at 5:52 AM
  • ellim
    I working on a system RW 5.16 and robot model IRB6640-205/2.75, recently facing the error as below:
    Error code 100000: Internal Error
    Description: Servots.c 7016 Cannot move robot in state CONTROL OFF.MG=0
    Description: Servo.c 2121 Control on Timeout
    May I know what is the root cause of this error?
  • Lemster68
    301
    2,472
    Blog Articles
    7
    • August 21, 2023 at 1:51 PM
    Look in the event log for concurrent or previous errors which could be the root cause. Look into hardware, especially.
  • ellim
    • August 21, 2023 at 5:00 PM
    In the event log there is no others error on that time.
  • ColoradoTaco
    16
    103
    • August 22, 2023 at 12:26 AM
    Make sure you have a good backup. Then do a B-Start. If that doesn't fix it, I-Start then restore your backup.
    Often, these errors are just an internal code glitch that will resolve on their own with a forced reload of the software.
    If the same error persists, I would also presume hardware related. Drive module or motor/brake contactors perhaps.
  • HanderFender
    • October 18, 2023 at 2:37 PM
    Quote from ellim
    Hello!
    I've encountered a similar issue. Were you able to find a solution?
    I tried to restore a backup, but it didn't help.
Similar Threads
  • Recording system data from a FANUC robot with the Karel program
    • AnisFrej
    • March 3, 2022 at 7:43 PM
    • Fanuc Robot Forum
  • I need config for abb irb 6400/f/2.4-150e s4
    • wowa_wa
    • February 10, 2022 at 8:42 PM
    • ABB Robot Forum
