Arc welding with coordinated motion
  • AdamS0205
  • August 19, 2023 at 1:42 PM
  • AdamS0205
    Dear Members,
    We are using a Fanuc Arc Mate 100iD with 2 pieces of FANUC two axis positioners for an arc welding task. For determining the start of weld, we have a 3rd party 3D camera mounted on robot`s 4th axis and this outputs the coordinates of the weld start point. We are using this as a USER FRAME and all welding points use this UFRAME, so this way we can compensate the deviations of product changes and welding fixture changes (welding fixtures are mounted on the 2 axis FANUC positioners).
    Unfortunately the welding angle is not ideal for all the points at the position where we can determine the start point(frame) with the 3D camera.
    The main objective would be to be able to determine the welding frame at one position of the positioner, after this, rotate it to the most ideal position of welding and weld it there. We got stuck in transforming the frame when the positioners are moved.
    Is there any way of achieving the task using coordinated motion and calibrating the positioners ?
  • MOM August 19, 2023 at 2:00 PM
    Approved the thread.
  • ROBOT_G
    23
    241
    • August 22, 2023 at 1:58 AM
    Coordinated pairs is what you need to read up on. They actually not hard to setup.
Similar Threads
  • Refpoints for weaving on positioner
    • quarz
    • November 18, 2022 at 8:57 PM
    • Yaskawa Motoman Robot Forum
  • MotoSIM simulate external axis
    • apakrat13
    • June 16, 2022 at 11:47 AM
  • disabling arc generation in auto?
    • jarm
    • January 22, 2022 at 3:20 PM
  • Weld Speed
    • jason@path-robotics
    • August 16, 2021 at 3:39 PM
  • Coordinated motion arc fault issue DX100
    • RobotguyX
    • June 24, 2021 at 6:24 PM
  • How do I Program a Positioner?
    • altonwelder
    • February 24, 2021 at 2:01 AM
    • Fanuc Robot Forum
  • Coordinated Motion and OTC weldset
    • Graney15118
    • November 6, 2019 at 4:14 PM
    • Fanuc Robot Forum
  • camera
  • user frame
  • POSITIONER
