Fanuc Robot connection
  • krgaurav22
  • August 18, 2023 at 7:29 AM
  • krgaurav22
    19
    I am using a Fanuc Robot CRX-10iA/L which is connected to my pc using ethernet cable. The connection works only when I switch off the wifi of the pc. If I switch on the wifi, the connection breaks. How can I have the wifi for internet as well as stay connected to the robot?
  • Roland Keller August 18, 2023 at 8:14 AM
    Approved the thread.
  • hermann
    412
    2,629
    • August 18, 2023 at 8:39 AM
    Look out for your PC documentation. Had this issue also on my laptop. There was a service from manufacturer HP running in background, that switched off LAN when wifi was active. And vice versa.
    gpunkt
    138
    494
    • August 18, 2023 at 8:52 AM
    This sounds like something for your IT-department to look into.
    Your computer should be able to handle multiple network interfaces simultaneously. From the top of my head it seems that your computer is setup so that only one interface can be active, and that there is a bias towards the wifi-interface.
    I've never encountered that problem. Just set your ethernet-interface on the computer to the same IP-subnet range and bada-bing!
  • AlanL
    22
    78
    • August 18, 2023 at 3:08 PM
    We have that where I work. It's part of the image on our computers, something to do with security, we are only able to use one network adapter at a time.
  • krgaurav22
    19
    • August 18, 2023 at 8:05 PM
    thanks for the suggestions. I am using Ubuntu. So, I unchecked the "Automatically Connect" option in the ethernet and now the wifi works as well. So, both the networks are working.
Similar Threads
  • FANUC robot late respond when receive a request
    • vinky1230
    • June 17, 2023 at 10:12 AM
    • Fanuc Robot Forum
  • How to connect TIA Portal with PLCSIM to fanuc robot, via KEPserverEX OPC UA connection
    • Krzysiex
    • June 27, 2023 at 11:36 AM
    • Fanuc Robot Forum
  • About the adaptation of robots and welding machines - a question from China
    • yzdtc2008
    • April 6, 2022 at 8:03 AM
    • Fanuc Robot Forum
  • SICK FTMG-ESD15AXX Flow/Pressure Meter Connection to Fanuc R30i OPC UA/MQTT
    • troxxx
    • March 21, 2023 at 2:09 AM
    • Fanuc Robot Forum
  • Process Simulate to Roboguide (Fanuc)
    • MoEL
    • September 7, 2021 at 7:52 PM
    • Siemens Process Simulate (Tecnomatix Robcad)
  • Ethernet IP connection - Invalid connection size
    • MellingTC
    • November 23, 2021 at 12:18 AM
    • Fanuc Robot Forum
  • Fanuc Karel Server, MSG_CONNECT exits with status 67206 without blocking
    • KlausSu
    • April 18, 2019 at 11:14 AM
    • Fanuc Robot Forum
  • Srvo-018 fault
    • apsitech
    • July 9, 2021 at 5:33 PM
    • Fanuc Robot Forum
  • Explicit Messaging between R30iB and OMRON PLC
    • Famous_Fella
    • March 12, 2020 at 10:24 AM
    • Fanuc Robot Forum
  • CRX-10iAl
