Hello all, my apologies for reaching out once more. while trying to solve error code "D1030" I have come across an issue with the Main CPU inside the controller, I have attached pictures to show a more in-depth look. I noticed a red light illuminating from a board, after following the code in line with the red light we saw that it signifies a CPU Error. Could this be a result of the "D1030" Error Code or another issue? I also shown a picture of a red light showing a server error on the Servo Board, I believe this plays a role into this error as well. Thank you so much for your time.
CPU Error
junior.j96 -
August 15, 2023 at 2:07 PM -
Closed -
Roland Keller
August 15, 2023 at 2:08 PM Approved the thread. -
Please stop creating threads relating to the same issue already being responding to by other members, this is the same as duplicating which is against forum rules and will not fast track for quicker responses.
FYI, how and where do you think error codes come from - CPU.
So if it was faulty, then probably the error codes would relate to something else.
As mentioned in your earlier post, sounds like the 1TB board, please replace it.
kwakisaki
August 15, 2023 at 7:16 PM Closed the thread.
