Fanuc Safety Fence Question
  • alive15
  • August 9, 2023 at 12:48 AM
  • alive15
    15
    161
    Good afternoon, I have a R30i-A Fanuc robot controller and working on wiring up the fence (EAS) section inside the panel. Am I able to run these two channels directly through a door interlock alone or do I need an additional safety relay? So when the door is closed, the two N.O. contacts on the door interlock itself will shut and then complete the circuit for the EAS1 and 2. The door interlock is safety rated. So whenever the door is open, it will immediately kill the EAS circuit and cause a fence fault on the robot.
    Thanks,
  • HawkME
    568
    3,268
    • August 9, 2023 at 4:02 AM
    • Best Answer
    An additional dual channel monitored safety relay would be used to achieve a higher safety rating. Your risk assessment would tell you the safety level required, but it would be best to use the safety relay.
  • alive15
    15
    161
    • August 9, 2023 at 3:46 PM
    Sounds good, thanks!
Similar Threads
  • Stupid Question - FANUC I/O
    • nutcase511
    • November 22, 2022 at 3:31 PM
    • Fanuc Robot Forum
  • Safety Fence and Light Curtain Wiring
    • zrehlander
    • March 28, 2022 at 6:22 PM
    • Fanuc Robot Forum
  • Stop position prediction
    • Jessica_NH
    • November 5, 2019 at 1:16 PM
    • Fanuc Robot Forum
